Espressif8266 exception decoder doesn't work
I don’t know what to do, my nodemcuv3 throws an excepton and i tried to decode it with the exception decoder. This is how i set it up:
platform = espressif8266
board = nodemcuv2
lib_deps = bogde/HX711@^0.7.5
monitor_filters = espressif8266_exception_decoder
However it changes nothing. How can i fix the decoder? This is what i get out:
Soft WDT reset
Exception (4):
epc1=0x4000dd11 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffd70 end: 3fffffd0 offset: 0160
3ffffed0:  feefeffe feefeffe feefeffe feefeffe
3ffffee0:  00000000 0031f6eb 3ffee518 000eca1c
3ffffef0:  feefeffe feefeffe feefeffe 00000000
3fffff00:  3ffee518 00000000 00000cca 40201d89
3fffff10:  00000000 00000cca 78d4fdf3 000eca1b
3fffff20:  40202eb5 00000001 00000020 0000000a
3fffff30:  3ffee518 00000cca 00000000 402025f4
3fffff40:  00000003 3ffee518 00000000 402012d4
3fffff50:  3ffef2dc 00000000 3ffee518 402012f9
3fffff60:  feefeffe 00000001 3ffee548 3ffee5c8
3fffff70:  00000000 00000001 3ffee548 0000000a
3fffff80:  3ffee518 00000000 00000000 402013ac
3fffff90:  00002580 0000001c 00000000 3ffee5c8
3fffffa0:  3fffdad0 00000000 3ffee518 4020145a
3fffffb0:  feefeffe feefeffe 3ffee59c 40201e30
3fffffc0:  feefeffe feefeffe 3fffdab0 40100dc5
<<<stack<<<
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
�E)�
�␌�9�H␂��h0�8�
Soft WDT reset
Exception (4):
epc1=0x4000dd33 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
3ffffee0:  00000000 0031fd6f 3ffee518 000ecc0a
3fffff00:  3ffee518 00000000 00000ccc 40201d89
3fffff10:  00000000 00000ccc 23d70a3d 000ecc09
3fffff30:  3ffee518 00000ccc 00000000 402025f4
<<<stack<<<
)(➍!␌H␂�hfHS␋�
Soft WDT reset
Exception (4):
epc1=0x40100214 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffd90 end: 3fffffd0 offset: 0160
3fffff00:  3ffee518 00000000 00000cc9 40201d89
3fffff10:  00000000 00000cc9 fb22d0e5 000ec98a
3fffff30:  3ffee518 00000cc9 00000000 402025f4
<<<stack<<<
��D␂��LH␂9.$jC␁�
Very thankful for your help
No debug symbols are generated without
build_type = debug
in the platformio.ini (docs). Add that, rebuild, reupload, monitor again. The trace should appear.
thank you very much, this helped
