Hi, I’m starting with PlatformIO on ESP32 and I’m getting this error:
cube@gecko ~/line_follower (v2) $ platformio run
Processing release (platform: espressif32; board: esp32doit-devkit-v1; framework: espidf)
PLATFORM: Espressif 32 1.12.4 > DOIT ESP32 DEVKIT V1
- framework-espidf 3.40001.200521 (4.0.1)
- tool-cmake 3.16.4
- tool-ninja 1.7.1
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32 2.80200.200827 (8.2.0)
Installing ESP-IDF's Python dependencies
ERROR: (Gentoo) Please run pip with the --user option to avoid breaking python-exec
*** Error 1
-- Project version: HW-v2.0.0-dirty
-- Building ESP-IDF components for target esp32
-- Checking Python dependencies...
The following Python requirements are not satisfied:
future>=0.15.2
pyparsing>=2.0.3,<2.4.0
Please refer to the Get Started section of the ESP-IDF Programming Guide for setting up the required packages.
Alternatively, you can run "/usr/lib/python-exec/python3.9/python -m pip install --user -r /home/cube/.platformio/packages/framework-espidf/requirements.txt" for resolving the issue.
-- Configuring incomplete, errors occurred!
See also "/home/cube/line_follower/.pio/build/release/CMakeFiles/CMakeOutput.log".
fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
CMake Error at /home/cube/.platformio/packages/framework-espidf/tools/cmake/build.cmake:270 (message):
Some Python dependencies must be installed. Check above message for
details.
/home/cube/.platformio/packages/framework-espidf/tools/cmake/build.cmake:396 (__build_check_python)
/home/cube/.platformio/packages/framework-espidf/tools/cmake/project.cmake:348 (idf_build_process)
CMakeLists.txt:3 (project)
================================================= [FAILED] Took 0.97 seconds =================================================
This looks like something during the build is trying to make a system wide install of some python packages. I have tried to create a venv and run platformio run
from inside it, but the error doesn’t change.
Is there some way to work around this (Other than installing / downgrading the dependencies as system packages)?
