We are pleased to announce the next release v2.3.0 of Espressif 8266 development platform .
What’s New
New boards:
Updated Arduino core to 2.6.1 (release notes )
Updated “esptoolpy” package to v2.8
Updated Xtensa toolchain to the latest version
See Espressif8266 Release Notes for details.
Documentation
Espressif 8266 — PlatformIO latest documentation
Examples
platform-espressif8266/examples at develop · platformio/platform-espressif8266 · GitHub
Update
PlatformIO IDE – please navigate to PIO Home > Platforms > Updates
PlatformIO Core – please run a next CLI command $ pio update
Regards,
The PlatformIO Team
And just when you think you’ve caught up with the espressif8266 arduino releases… they go and release 2.6.2 10 hours later!
Look forward to trying out 2.6.x … seems like there’s some good stuff happening there.
Well snap!
Here’s hoping it lasts a little longer! Thanks Ivan
HenkV
December 2, 2019, 12:32am
#5
Tried 2.3.0 and 2.3.1 but it doesn’t compile, problems with WiFiClientSecure
2.2.3 and earlier compile as it should but 2.3.0 and 2.3.1 complain about:
error: ‘using ESP8266WebServerSecure = class esp8266webserver::ESP8266WebServerTemplateBearSSL::WiFiServerSecure ’ has no member named ‘setBufferSizes’
‘using ESP8266WebServerSecure = class esp8266webserver::ESP8266WebServerTemplateBearSSL::WiFiServerSecure ’ has no member named ‘setRSACert’
Should I change something else? Again, it compiles under 2.2.3 and lower
platform = espressif8266@2.3.1 // 2.2.3 = ok
board = d1_mini
Without seeing a MVCE / reproducible code example it’s hard to tell. Do the examples provided by the esp8266 Arduino board support package work for you? As you can see, with platform = espressif8266@2.3.1
both of these example sketches work fine.
Example code using setRSACert.
Processing d1_mini (framework: arduino; platform: espressif8266@2.3.1; board: d1_mini)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini.html
PLATFORM: Espressif 8266 2.3.1 > WeMos D1 R2 and mini
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
PACKAGES: toolchain-xtensa 2.40802.191122 (4.8.2), tool-esptool 1.413.0 (4.13), tool-esptoolpy 1.20800.0 (2.8.0), framework-arduinoespressif8266 2.20602.191128 (2.6.2)
Found 29 compatible libraries
|-- <ESP8266WiFi> 1.0
|-- <ESP8266mDNS> 1.2
|-- <ESP8266WebServer> 1.0
Retrieving maximum program size .pio\build\d1_mini\firmware.elf
Checking size .pio\build\d1_mini\firmware.elf
RAM: [=== ] 34.5% (used 28276 bytes from 81920 bytes)
Flash: [==== ] 42.0% (used 438788 bytes from 1044464 bytes)
========================================================== [SUCCESS] Took 12.32 seconds ==========================================================
Example using setBufferSizes
RAM: [=== ] 34.1% (used 27928 bytes from 81920 bytes)
Flash: [==== ] 36.5% (used 381424 bytes from 1044464 bytes)
========================================================== [SUCCESS] Took 11.47 seconds ==========================================================
HenkV
December 2, 2019, 7:56am
#7
Thanks, I see there have been some changes:
server.setBufferSizes
server.setRSACert
have become
server.getServer().setBufferSizes
server.getServer().setRSACert
Now it is compiling
edit… after compiling and testing:
I gained almost 2kb free heap with the new 2.3.1 Very good !!!
Regards,
Henk
Yeah, I saw there was mention of…
Changes since 2.4.2 (to 2.5.0)
Breaking change
SSL/TLS API (BearSSL)
… in the release notes , but that would mean espressif8266@>2.0.0 would have those changes… so I don’t know what was the cause of that change to the API.
Anyway, obviously it’s working for you now!
