We are pleased to announce the next release v1.9.0 of Espressif 32 development platform.
What’s New
See Espressif32 Release Notes for details.
Documentation
Espressif 32 — PlatformIO latest documentation
Examples
platform-espressif32/examples at develop · platformio/platform-espressif32 · GitHub
Update
- PlatformIO IDE – please navigate to
PIO Home > Platforms > Updates
- PlatformIO Core – please run a next CLI command
$ pio update
Regards,
The PlatformIO Team
Dear @ivankravets
I working on creating a component which uses ULP for coming up back from deep sleep mode based on ADC value. Following is tree of component directory:
├── CMakeLists.txt
├── component.mk
├── include
│ └── sleep_mode_management.h
├── Kconfig.projbuild
├── sleep_mode_management.c
└── ulp
└── adc.S
The CMakeLists.txt contents are following
idf_component_register(SRCS "sleep_mode_management.c"
INCLUDE_DIRS "include"
REQUIRES soc nvs_flash ulp driver)
# ULP support additions to component CMakeLists.txt.
# 1. The ULP app name must be unique (if multiple components use ULP).
set(ulp_app_name ulp_adc)
# 2. Specify all assembly source files.
# Files should be placed into a separate directory (in this case, ulp/),
# which should not be added to COMPONENT_SRCS.
set(ulp_s_sources "ulp/adc.S")
# 3. List all the component source files which include automatically
# generated ULP export file, ${ulp_app_name}.h:
set(ulp_exp_dep_srcs "sleep_mode_management.c")
# 4. Call function to build ULP binary and embed in project using the argument
# values above.
ulp_embed_binary(${ulp_app_name} ${ulp_s_sources} ${ulp_exp_dep_srcs})
Unfortunately, I’m facing the problem of ulp_adc.h not found. I have upgraded to the version of 3.2.2 of ESP-IDF. Can you please guide me how can I fix this issue.
Where is that file in ESP-IDF? I can’t find it in File Finder · GitHub.
You probably mean platform-espressif32 version 3.2.2, which gives you ESP-IDF v4.3.
I have created my own component. Therefore you can not find it on Github repository. According to the documentation of ESP-IDF.
Yes, by 3.2.2 I means platform-espressif32 version.
So the ulp_adc.h is in your project folder? I don’t see it in
