I’ve just discovered PlatformIO and wish to thank everyone involved for this great development tool. And to wish God speed to the peoples of Ukraine during these deeply trying times.
My issue is with building ESPNOW code for the ESP-01 board. Compile errors are all centered around 'espnowxxx was not declared in this scope’ errors, it’s as if a header file is missing. But I have included what I think are the correct include files:
#include <ESP8266WiFi.h>
#include <espnow.h>
Please can anyone shed light on these errors. I have successfully uploaded and executed various WiFi examples to this ESP-01 board which all work fine, it’s appears only ESPNOW is presenting a problem.
Many thanks,
Jack.
platformio.ini
[env:esp01_1m]
platform = espressif8266
board = esp01_1m
upload_port = COM5
Code:
#include <espnow.h>
bool buttonDown = false;
bool ledOn = false;
void formatMacAddress(const uint8_t *macAddr, char *buffer, int maxLength)
snprintf(buffer, maxLength, "%02x:%02x:%02x:%02x:%02x:%02x", macAddr[0], macAddr[1], macAddr[2], macAddr[3], macAddr[4], macAddr[5]);
void receiveCallback(const uint8_t *macAddr, const uint8_t *data, int dataLen)
// only allow a maximum of 250 characters in the message + a null terminating byte
char buffer[ESP_NOW_MAX_DATA_LEN + 1];
int msgLen = min(ESP_NOW_MAX_DATA_LEN, dataLen);
strncpy(buffer, (const char *)data, msgLen);
// make sure we are null terminated
buffer[msgLen] = 0;
// format the mac address
char macStr[18];
formatMacAddress(macAddr, macStr, 18);
// debug log the message to the serial port
Serial.printf("Received message from: %s - %s\n", macStr, buffer);
// what are our instructions
if (strcmp("on", buffer) == 0)
ledOn = true;
else
ledOn = false;
digitalWrite(2, ledOn);
// callback when data is sent
void sentCallback(const uint8_t *macAddr, esp_now_send_status_t status)
char macStr[18];
Serial.print("Last Packet Sent to: ");
Serial.println(macStr);
Serial.print("Last Packet Send Status: ");
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
void broadcast(const String &message)
// this will broadcast a message to everyone in range
uint8_t broadcastAddress[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
esp_now_peer_info_t peerInfo = {};
memcpy(&peerInfo.peer_addr, broadcastAddress, 6);
if (!esp_now_is_peer_exist(broadcastAddress))
esp_now_add_peer(&peerInfo);
esp_err_t result = esp_now_send(broadcastAddress, (const uint8_t *)message.c_str(), message.length());
// and this will send a message to a specific device
/*uint8_t peerAddress[] = {0x3C, 0x71, 0xBF, 0x47, 0xA5, 0xC0};
memcpy(&peerInfo.peer_addr, peerAddress, 6);
if (!esp_now_is_peer_exist(peerAddress))
esp_err_t result = esp_now_send(peerAddress, (const uint8_t *)message.c_str(), message.length());*/
if (result == ESP_OK)
Serial.println("Broadcast message success");
else if (result == ESP_ERR_ESPNOW_NOT_INIT)
Serial.println("ESPNOW not Init.");
else if (result == ESP_ERR_ESPNOW_ARG)
Serial.println("Invalid Argument");
else if (result == ESP_ERR_ESPNOW_INTERNAL)
Serial.println("Internal Error");
else if (result == ESP_ERR_ESPNOW_NO_MEM)
Serial.println("ESP_ERR_ESPNOW_NO_MEM");
else if (result == ESP_ERR_ESPNOW_NOT_FOUND)
Serial.println("Peer not found.");
else
Serial.println("Unknown error");
void setup()
delay(1000);
//Set device in STA mode to begin with
WiFi.mode(WIFI_STA);
Serial.println("ESPNow Example");
// Output my MAC address - useful for later
Serial.print("My MAC Address is: ");
Serial.println(WiFi.macAddress());
// shut down wifi
WiFi.disconnect();
// startup ESP Now
if (esp_now_init() == ESP_OK)
Serial.println("ESPNow Init Success");
esp_now_register_recv_cb(receiveCallback);
esp_now_register_send_cb(sentCallback);
else
Serial.println("ESPNow Init Failed");
delay(3000);
ESP.restart();
// use the built in button
pinMode(0, INPUT_PULLUP);
pinMode(2, OUTPUT);
void loop()
if (digitalRead(0))
// detect the transition from low to high
if (!buttonDown)
buttonDown = true;
// toggle the LED state
ledOn = !ledOn;
// send a message to everyone else
if (ledOn)
broadcast("on");
else
broadcast("off");
// delay to avoid bouncing
delay(500);
else
// reset the button state
buttonDown = false;
Build Log:
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp01_1m.html
PLATFORM: Espressif 8266 (3.2.0) > Espressif Generic ESP8266 ESP-01 1M
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
- framework-arduinoespressif8266 3.30002.0 (3.0.2)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa 2.100300.210717 (10.3.0)
Found 35 compatible libraries
|-- <ESP8266WiFi> 1.0
Compiling .pio\build\esp01_1m\src\main.cpp.o
Compiling .pio\build\esp01_1m\libd82\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o
Compiling .pio\build\esp01_1m\libd82\ESP8266WiFi\ESP8266WiFiGratuitous.cpp.o
Compiling .pio\build\esp01_1m\libd82\ESP8266WiFi\ESP8266WiFiMulti.cpp.o
Compiling .pio\build\esp01_1m\libd82\ESP8266WiFi\ESP8266WiFiSTA-WPS.cpp.o
src\main.cpp: In function 'void receiveCallback(const uint8_t*, const uint8_t*, int)':src\main.cpp:16:15: error: 'ESP_NOW_MAX_DATA_LEN' was not declared in this scope
16 | char buffer[ESP_NOW_MAX_DATA_LEN + 1];
src\main.cpp:18:11: error: 'buffer' was not declared in this scope; did you mean 'setbuffer'?
18 | strncpy(buffer, (const char *)data, msgLen);
| setbuffer
src\main.cpp: At global scope:
src\main.cpp:39:43: error: 'esp_now_send_status_t' has not been declared
39 | void sentCallback(const uint8_t *macAddr, esp_now_send_status_t status)
src\main.cpp: In function 'void sentCallback(const uint8_t*, int)':
src\main.cpp:46:28: error: 'ESP_NOW_SEND_SUCCESS' was not declared in this scope
46 | Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
src\main.cpp: In function 'void broadcast(const String&)':
src\main.cpp:53:3: error: 'esp_now_peer_info_t' was not declared in this scope; did you mean 'esp_now_deinit'?
53 | esp_now_peer_info_t peerInfo = {};
| esp_now_deinit
src\main.cpp:54:11: error: 'peerInfo' was not declared in this scope
54 | memcpy(&peerInfo.peer_addr, broadcastAddress, 6);
src\main.cpp:59:3: error: 'esp_err_t' was not declared in this scope
59 | esp_err_t result = esp_now_send(broadcastAddress, (const uint8_t *)message.c_str(), message.length());
src\main.cpp:69:7: error: 'result' was not declared in this scope
69 | if (result == ESP_OK)
src\main.cpp:69:17: error: 'ESP_OK' was not declared in this scope; did you mean 'ERR_OK'?
| ERR_OK
src\main.cpp:73:22: error: 'ESP_ERR_ESPNOW_NOT_INIT' was not declared in this scope
73 | else if (result == ESP_ERR_ESPNOW_NOT_INIT)
src\main.cpp:77:22: error: 'ESP_ERR_ESPNOW_ARG' was not declared in this scope
77 | else if (result == ESP_ERR_ESPNOW_ARG)
src\main.cpp:81:22: error: 'ESP_ERR_ESPNOW_INTERNAL' was not declared in this scope
81 | else if (result == ESP_ERR_ESPNOW_INTERNAL)
src\main.cpp:85:22: error: 'ESP_ERR_ESPNOW_NO_MEM' was not declared in this scope
85 | else if (result == ESP_ERR_ESPNOW_NO_MEM)
src\main.cpp:89:22: error: 'ESP_ERR_ESPNOW_NOT_FOUND' was not declared in this scope
89 | else if (result == ESP_ERR_ESPNOW_NOT_FOUND)
src\main.cpp: In function 'void setup()':
src\main.cpp:112:25: error: 'ESP_OK' was not declared in this scope; did you mean 'ERR_OK'?
112 | if (esp_now_init() == ESP_OK)
| ERR_OK
src\main.cpp:115:30: error: invalid conversion from 'void (*)(const uint8_t*, const uint8_t*, int)' {aka 'void (*)(const unsigned char*, const unsigned char*, int)'} to 'esp_now_recv_cb_t' {aka 'void (*)(unsigned char*, unsigned char*, unsigned char)'} [-fpermissive]
115 | esp_now_register_recv_cb(receiveCallback);
| void (*)(const uint8_t*, const uint8_t*, int) {aka void (*)(const unsigned char*, const unsigned char*, int)}
In file included from src\main.cpp:3:
C:\Users\user\.platformio\packages\framework-arduinoespressif8266\tools\sdk\include/espnow.h:50:48: note: initializing argument 1 of 'int esp_now_register_recv_cb(esp_now_recv_cb_t)'
50 | int esp_now_register_recv_cb(esp_now_recv_cb_t cb);
src\main.cpp:116:30: error: invalid conversion from 'void (*)(const uint8_t*, int)' {aka 'void (*)(const unsigned char*, int)'} to 'esp_now_send_cb_t' {aka 'void (*)(unsigned char*, unsigned char)'} [-fpermissive]
116 | esp_now_register_send_cb(sentCallback);
| void (*)(const uint8_t*, int) {aka void (*)(const unsigned char*, int)}
C:\Users\user\.platformio\packages\framework-arduinoespressif8266\tools\sdk\include/espnow.h:47:48: note: initializing argument 1 of 'int esp_now_register_send_cb(esp_now_send_cb_t)'
47 | int esp_now_register_send_cb(esp_now_send_cb_t cb);
*** [.pio\build\esp01_1m\src\main.cpp.o] Error 1
============================= [FAILED] Took 3.28 seconds =============================The terminal process "C:\Users\user\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
