Using the@maxgerhardt example from GitHub - maxgerhardt/pio-espidf-arduino-repro: (Do not use, only for reproduction)
fails with this error:
c:/users/peter/.platformio/packages/toolchain-xtensa32@2.80200.200827/bin/…/lib/gcc/xtensa-esp32-elf/8.2.0/…/…/…/…/xtensa-esp32-elf/bin/ld.exe: cannot find -lUsersPeter.platformiopackagesframework-espidf@3.40001.200521componentsxtensaesp32libhal
platform.ini is unmodified from the example.
does anyone have an example arduino-espidf that currently works?
OK, after much thrashing about, this appear to be some kind of tool chain corruption. I mostly fixed the issue by uninstalling PIO from VSCode and deleting the .platformio directory and then reinstalling PIO. (OS is Win 10)
so now example blink builds as well as my own arduino-esp32 code but i do get an “error” in installing windows-curses. Is windows-curses required??
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 (3.3.1+sha.33ff413) > Espressif ESP32 Dev Module
DEBUG: Current (jlink) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 0.0.0+sha.d011dd7
- framework-espidf 3.40001.200521 (4.0.1)
- tool-cmake 3.16.4
- tool-esptoolpy 1.30100.210531 (3.1.0)
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- tool-openocd-esp32 2.1000.20210721 (10.0)
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32 2.80400.210211 (8.4.0)
Installing windows-curses package
Processing c:\users\peter.platformio\packages\framework-espidf\tools\kconfig_new\esp-windows-curses
ERROR: Could not install packages due to an OSError: [Errno 2] No such file or directory: ‘C:\Users\Peter\.platformio\packages\framework-espidf\tools\kconfig_new\esp-windows-curses’
*** Error 1
