I’m using VSCode on Ubuntu 20.04.5. Sanity check LED-blink project for Arduino Leonardo builds and runs fine. I started playing with DOIT ESPDUINO32 board. The new project as generated by IDE fails to build with this output:
> Executing task: platformio run <
Processing esp32doit-espduino (platform: espressif32; board: esp32doit-espduino; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32doit-espduino.html
PLATFORM: Espressif 32 (3.4.0) > DOIT ESPduino32
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 28 compatible libraries
Compiling .pio/build/esp32doit-espduino/src/main.cpp.o
Compiling .pio/build/esp32doit-espduino/FrameworkArduino/Esp.cpp.o
Compiling .pio/build/esp32doit-espduino/FrameworkArduino/FunctionalInterrupt.cpp.o
In file included from src/main.cpp:1:0:
/home/paul/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:185:26: fatal error: pins_arduino.h: No such file or directory
Do I need to install a dependency? Provided link: PlatformIO Registry doesn’t offer a clear choice. What is the solution?
