Hi!
When i take the example “esp8266-webserver” it compiles ok.
when i insert:
[platformio]
envs_dir = /tmp/foo
it compiles with the error:
.text' will not fit in regioniram1_0_seg’
PlatformIO, version 2.9.2.dev0
any suggestions?
Robert
Hi!
when i insert:
[platformio]
envs_dir = /tmp/foo
any suggestions?
Robert
Hi @Robert_Walli!
Yes, we know about this issue with envs_dir option and espressif platform, but there is a temporary workaround: adding .pioenvs directory to a new environment path. For example:
[platformio]
envs_dir = /tmp/.pioenvs
Hi!
Workaround ist OK.
Tried now with version 2.9.2, 2.9.3 and 2.9.4, guess it will not be fixed in 2.x ?
Robert
You will be able to fork original espressif development platform in PlatformIO 3.0 and create own. The issue is linked with LD script where .pioenvs is hard coded. See https://github.com/platformio/platform-espressif/blob/develop/ldscripts/esp8266.flash.common.ld#L156:L162
