I am trying to flash a script to a ESP8266 which is connected to a Raspberry Pi 4B but it is not working. This is the output I get:
Processing esp8266 (platform: espressif8266; board: esp12e; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp12e.html
PLATFORM: Espressif 8266 (4.2.0) > Espressif ESP8266 ESP-12E
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 @ 3.30102.0 (3.1.2)
- tool-esptool @ 1.413.0 (4.13)
- tool-esptoolpy @ 1.30000.201119 (3.0.0)
- tool-mkspiffs @ 1.200.0 (2.0)
- toolchain-xtensa @ 2.100300.220621 (10.3.0)
Found 53 compatible libraries
|-- NTPClient @ 3.2.1
|-- RemoteDebug @ 2.1.2
| |-- ESP8266WiFi @ 1.0
|-- PubSubClient @ 2.8.0
|-- Sensirion I2C SCD4x @ 0.3.1
| |-- Wire @ 1.0
| |-- Sensirion Core @ 0.6.0
| | |-- Wire @ 1.0
|-- Adafruit SHT31 Library @ 2.2.0
| |-- Adafruit BusIO @ 1.14.1
| | |-- Wire @ 1.0
| | |-- SPI @ 1.0
| |-- Wire @ 1.0
|-- Adafruit TSL2561 @ 1.1.0
| |-- Adafruit Unified Sensor @ 1.1.9
| |-- Wire @ 1.0
|-- Adafruit AS7341 @ 1.3.3
| | |-- Wire @ 1.0
| | |-- SPI @ 1.0
| |-- Wire @ 1.0
| |-- SPI @ 1.0
|-- DFRobot_BMP3XX @ 1.0.3
| |-- SPI @ 1.0
| |-- Wire @ 1.0
|-- ModbusMaster @ 2.0.1
|-- Adafruit TMP117 @ 1.0.1
| | |-- Wire @ 1.0
| | |-- SPI @ 1.0
| |-- Wire @ 1.0
| |-- SPI @ 1.0
|-- ArduinoJson @ 6.21.2
|-- ArduinoOTA @ 1.0
| |-- ESP8266mDNS @ 1.2
|-- EspSoftwareSerial @ 8.0.1
|-- Wire @ 1.0
Compiling .pio/build/esp8266/src/main.cpp.o
sh: 1: xtensa-lx106-elf-g++: not found
Generating LD script .pio/build/esp8266/ld/local.eagle.app.v6.common.ld
sh: 1: xtensa-lx106-elf-gcc: not found
Compiling .pio/build/esp8266/lib213/NTPClient/NTPClient.cpp.o
*** [.pio/build/esp8266/src/main.cpp.o] Error 127
Compiling .pio/build/esp8266/lib46a/ESP8266WiFi/BearSSLHelpers.cpp.o
*** [.pio/build/esp8266/ld/local.eagle.app.v6.common.ld] Error 127
*** [.pio/build/esp8266/lib213/NTPClient/NTPClient.cpp.o] Error 127
*** [.pio/build/esp8266/lib46a/ESP8266WiFi/BearSSLHelpers.cpp.o] Error 127
=================[FAILED] Took 6.14 seconds ========================
I tried deleting the directories in ~/.platformio/packages as well as the .cache folder, but the error still persists.
Does anyone know how to solve this problem? I am using Pio Core version is 6.1.6.
Thanks!
