I am trying to use PlatformIO via Atom, to build and upload to an ESP8266 (Node MCU, ESP-12E). I’ve installed the CP210X Drivers, as noted on the board itself, but I only get:
MacBook-Pro-3:smart-bed-sensor-master mfd356$ pio device list
/dev/cu.Bluetooth-Incoming-Port
Hardware ID: n/a
Description: n/a
/dev/cu.iPhone-WirelessiAPv2
Hardware ID: n/a
Description: n/a
I’m using Atom v. 1.32.2 64x and PlatformIO (home: 1.0.6), (core: 3.6.2b5) on OSX High Sierra (XCode v 10.1).
This is my first attempt with both PlatformIO and an ESP8266 board, so it’s very likely that it’s something stupid that I just haven’t figured out, or been able to google.
Are you able to see the the serial port / board under the USB settings? Can you upload via Arduino IDE? If not, your problem is that you didn’t install the drivers correctly, didn’t reboot or installed the wrong drivers.
After installing the ones that were described on the board, I see something under the OS device manager (or whatever they call it on OSX) when connecting the board.
But nothing showed up in the Arduino IDE ports, just the two I initially found via PlatformIO.
I’ve subsequently installed other drivers; I tried this guide, that links to drivers published by codebender, as we as these drivers but same story.
I have rebooted each time after installing drivers. I’m not sure if there is a wrong way to install the drivers; they come as either .pkg or .dmg, so it’s just running it.
Any idea about which drivers would actually work? None of the ones I have found seem to do the job.
However, I dusted off my old Windows Desktop, installed drivers (found on the same website as the initial ones I tried on the Mac), and this worked with no issues.
