Hallo,
I switched from Arduino IDE to PlatformIO a half year ago. PlatformIO is a great product. I was able to structure my code for my ESP8266 and ESP32’s in a way that wasn’t possible with Arduino IDE.
Also the compilations are very fast and gives me a lot more control.
Hence I have a question. I want to increase the heap, to try to use the bear ssl client with a extensive code for my esp8266. I run a standard webserver in the esp and some advances features for processing sensors, actuators etc.
But for using a ssl client to communicate securely to my domotic solution, I run out of heap.
In the arduino IDE there is a option, to customise the memory allocation, but I can’t find the way to do that with PlatformIO.
See: PoC cache configuration control by mhightower83 · Pull Request #7060 · esp8266/Arduino · GitHub
Is there a way to do this in platform IO?
First of all, as someone who worked with an ESP8266 + TLS, connecting to some TLS websites is just impossible if they use big certificate chains and inefficient algorithms like RSA instead of ECC-based stuff, even if you have a little bit more memory, they’d need a lot more memory – some things are just out of reach for an ESP8266.
Second of all, the MMU feature is only available in the new 3.0.0 core for which PlatformIO doesn’t yet built-in support, see Arduino Core 3.0, when?. However, with certatin configuration options as outlined in this thread, it’s possible to get the 3.0.0 version.
Further if I read
correctly then the different MMU / heap options just boil down to adding a few macros to the build process, which we can do as well using build_flags.
So if you want the e.g. the 16KB cache + 48KB IRAM and 2nd Heap (shared) option, you would add the corresponding mmuflags as
build_flags = -DMMU_IRAM_SIZE=0xC000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_IRAM_HEAP
to the platformio.ini.
I have not tested this at the moment.
The MMU options would be documented in Espressif 8266 — PlatformIO latest documentation but aren’t now; this is because PlatformIO officially supports only up to core version 2.7.4 and not the new 3.0.0 as of now. If PlatformIO updates, those options should be added.
Yes that definitely works. If I do
[env:esp8266]
platform = espressif8266
board = nodemcuv2
platform_packages =
framework-arduinoespressif8266@https://github.com/esp8266/Arduino.git#3.0.0
mcspr/toolchain-xtensa@~5.100200.0
monitor_speed = 74880
upload_speed = 921600
with code
#include <umm_malloc/umm_heap_select.h>
void setup()
Serial.begin(74880);
HeapSelectIram ephemeral;
Serial.printf("IRAM free: %6d bytes\r\n", ESP.getFreeHeap());
HeapSelectDram ephemeral;
Serial.printf("DRAM free: %6d bytes\r\n", ESP.getFreeHeap());
I get
IRAM free: 21592 bytes
DRAM free: 52336 bytes
^~^ so the options are totally usable.
As you can see in here they also already updated the platformio-build.py script for PlatformIO integration.
Your solution works like charm. Thanks.
Great to hear, just keep a watch on Update core to 3.0.0 · Issue #249 · platformio/platform-espressif8266 · GitHub and Releases · platformio/platform-espressif8266 · GitHub for when an official update for platform-espressif8266 is released; then you should use that via a normal update (PIO Home → Platforms → Update) instead of platform_packages modifications above.
