> Executing task: C:\Users\DNS\.platformio\penv\Scripts\platformio.exe run --target buildfs --environment esp_wroom_02 <
Processing esp_wroom_02 (platform: espressif8266; framework: esp8266-rtos-sdk; board: esp_wroom_02)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp_wroom_02.html
PLATFORM: Espressif 8266 (2.6.3) > ESP-WROOM-02
HARDWARE: ESP8266 80MHz, 80KB RAM, 2MB Flash
- framework-esp8266-rtos-sdk 1.5.0-beta.5
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-mklittlefs 1.203.210203 (2.3)
- tool-mkspiffs 1.200.0 (2.0)
- toolchain-xtensa 1.40802.0 (4.8.2)
Found 0 compatible libraries
AssertionError: :
File "C:\Users\DNS\.platformio\penv\Lib\site-packages\platformio\builder\main.py", line 178:
File "C:\Users\DNS\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 591:
File "C:\Users\DNS\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 280:
File "C:\Users\DNS\.platformio\platforms\espressif8266\builder\main.py", line 243:
target_firm = env.DataToBin(
File "C:\Users\DNS\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Environment.py", line 238:
return super().__call__(target, source, *args, **kw)
File "C:\Users\DNS\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Util.py", line 658:
File "C:\Users\DNS\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Builder.py", line 650:
return self._execute(env, target, source, OverrideWarner(kw), ekw)
File "C:\Users\DNS\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Builder.py", line 560:
tlist, slist = self._create_nodes(env, target, source)
File "C:\Users\DNS\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Builder.py", line 522:
target, source = self.emitter(target=tlist, source=slist, env=env)
File "C:\Users\DNS\.platformio\platforms\espressif8266\builder\main.py", line 119:
fetch_fs_size(env)
File "C:\Users\DNS\.platformio\platforms\espressif8266\builder\main.py", line 98:
assert all([
======================================= [FAILED] Took 3.75 seconds =======================================
Environment Status Duration
esp_wroom_02 FAILED 00:00:03.749
================================== 1 failed, 0 succeeded in 00:00:03.749 ==================================
The terminal process "C:\Users\DNS\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'buildfs', '--environment', 'esp_wroom_02'" terminated with exit code: 1.
Filesystem building does not work for this SDK. The Python logic expects a linker script which exports certain symbols (PROVIDE( .._FS_... = ....)) so that it knows where the filesystem starts and ends, along other information.
Compare the used script(s) in ESP8266_RTOS_SDK/ld at 1.4.x · espressif/ESP8266_RTOS_SDK · GitHub vs
Ways to fix that would be to adapt the used linker script (locally in e.g. ~/.platformio/packages/framework-esp8266-rtos-sdk/ld/eagle.app.v6.ld and related), or relocate the used linker script to a different file that has these symbols per docs.
However, it would be best to just request direct support, at Issues · platformio/platform-espressif8266 · GitHub.
thanks, I will try the first method, if it doesn’t work, I will ask here
https://github.com/platformio/platform-espressif8266/issues/
