Hi community
I have been using the arduino IDE during many months with UNO, ESP8266 and ESP32 and everything is OK. My machine is using Linix MINT 20.1 Xfce 64 bit
But now I want to use the platformIO. I am trying to uploud the classical BLINK sketch (very easy sketch) to my esp32wroom32u, but it do not work. There is something wrong with the bootload,
This is the second time I am trying to resolve this problem, first time was 2 months ago.
Could someone help me?
Thank you and best regards
Leonardo
Tha plattformIO.ini is:
When I am trying to upload the BLINK I am recieveing the next messages:
Processing uno (platform: atmelavr; board: uno; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (3.4.0) > Arduino Uno
- framework-arduino-avr 5.1.0
Found 5 compatible libraries
Checking size .pio/build/uno/firmware.elf
RAM: [ ] 0.4% (used 9 bytes from 2048 bytes)
Flash: [ ] 2.9% (used 924 bytes from 32256 bytes)
AVAILABLE: arduino
Looking for upload port...
Auto-detected: /dev/ttyUSB0
Uploading .pio/build/uno/firmware.hex
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
*** [upload] Error 1
==================================================== [FAILED] Took 52.07 seconds ====================================================
The terminal process "platformio 'run', '--target', 'upload'" terminated with exit code: 1.
