Esp32thing serial monitor broken
I’m trying to run the espidf-hello-world example on my esp32thing board, and I’m having problems with the serial.
My monitor_speed is set to 115200 in my platfomio.ini file.
Some notes:
  • The bootloader, which runs at 115200 prints out just fine
  • I’ve tried using gnu screen, and received the same results.
  • I’ve tried erasing the flash with esptool and reprogramming
  • I’ve tried selecting a couple of other bauds, but I’m still getting gibberish.
  • I’m using the latest platformio
  • My blink example is unmodified, with the exception of platformio.ini, which is pasted below
  • Tried arduino platform WiFiScan example with same board, and serial seems to work fine.
platformio.ini
[env:esp32thing]
framework = espidf
board = esp32thing
Below is an example of what the monitor outputs:
For reference, here is my compile log:
Processing esp32thing (platform: espressif32; monitor_speed: 115200; board: esp32thing; framework: espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32thing.html
PLATFORM: Espressif 32 > SparkFun ESP32 Thing
HARDWARE: ESP32 240MHz 320KB RAM (4MB Flash)
DEBUG: CURRENT(esp-prog) EXTERNAL(esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
Collected 0 compatible libraries
<lambda>(["checkprogsize"], [".pioenvs/esp32thing/firmware.elf"])
MethodWrapper(["checkprogsize"], [".pioenvs/esp32thing/firmware.elf"])
DATA:    [          ]   3.8% (used 12344 bytes from 327680 bytes)
PROGRAM: [=         ]  12.4% (used 130501 bytes from 1048576 bytes)
.pioenvs/esp32thing/firmware.elf  :
section            size         addr
.rtc.text             0   1074528256
.rtc_noinit           0   1342177280
.iram0.vectors     1024   1074266112
.iram0.text       31156   1074267136
.dram0.data        8168   1073479680
.noinit               0   1073487848
.dram0.bss         4176   1073487848
.flash.rodata     22052   1061158944
.flash.text       68101   1074593816
.comment            244            0
.xtensa.info         56            0
.debug_line       72785            0
.debug_info       89418            0
.debug_abbrev     14780            0
.debug_aranges     1400            0
.debug_str         5834            0
.debug_frame       2168            0
.debug_loc        76508            0
.debug_ranges       952            0
Total            398822
<lambda>(["upload"], [".pioenvs/esp32thing/firmware.bin"])
AVAILABLE: esp-prog, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
MethodWrapper(["upload"], [".pioenvs/esp32thing/firmware.bin"])
Use manually specified: /dev/ttyUSB0
"/home/bkinman/.platformio/penv/bin/python2.7" "/home/bkinman/.platformio/packages/tool-esptoolpy/esptool.py" --chip esp32 --port "/dev/ttyUSB0" --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 /home/bkinman/Documents/PlatformIO/Projects/190211-094748-espidf-hello-world/.pioenvs/esp32thing/bootloader.bin 0x8000 /home/bkinman/Documents/PlatformIO/Projects/190211-094748-espidf-hello-world/.pioenvs/esp32thing/partitions.bin 0x10000 .pioenvs/esp32thing/firmware.bin
esptool.py v2.6
Serial port /dev/ttyUSB0
Connecting........_____....._
Chip is ESP32D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
MAC: 30:ae:a4:bc:01:6c
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 19632 bytes to 12007...
Writing at 0x00001000... (100 %)
Wrote 19632 bytes (12007 compressed) at 0x00001000 in 0.1 seconds (effective 1089.5 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 103...
Wrote 3072 bytes (103 compressed) at 0x00008000 in 0.0 seconds (effective 1556.7 kbit/s)...
Compressed 133712 bytes to 65261...
Writing at 0x00010000... (25 %)
Writing at 0x00014000... (50 %)
Writing at 0x00018000... (75 %)
Writing at 0x0001c000... (100 %)
Wrote 133712 bytes (65261 compressed) at 0x00010000 in 1.2 seconds (effective 928.6 kbit/s)...
Leaving...
Hard resetting via RTS pin...
========================================================================================================== [SUCCESS] Took 24.81 seconds ==========================================================================================================
There is mention here of
The Sparkfun Thing has a 26MHz crystal, while esp-idf is by default configured for an 40MHz crystal. In ‘make menuconfig’, if memory serves under components -> esp32 specific, you can change the crystal frequency.
If that is the source of your problem, I don’t know, and since I haven’t pulled my ESP32s out yet and tried them with PlatformIO, I don’t know how you go about configuring that sort of stuff… maybe you do run make menuconfig at the terminal? I’m sure someone else will jump in if you’re still stuck…
Thanks @pfeerick, this was the problem!
The default sdkconfig.h was incorrect.
For anybody else running into this issue, I made the following changes to sdkconfig.h:
  • Remove: #define CONFIG_ESP32_XTAL_FREQ_40 1
  • Remove: #define CONFIG_ESP32_XTAL_FREQ 40
  • Add: #define CONFIG_ESP32_XTAL_FREQ_AUTO 1
  • Add #define CONFIG_ESP32_XTAL_FREQ 0
