Hello folks,
I have an Adafruit ESP32S3 TFT Reverse. I used it to build a data logger.
I initially developed the data logger in the Arduino IDE. I use this for a quick proof of work.
I would now like to move this data logger to an ESP32S3 dev board. Because it has more internal memory (16MB) and I don’t need the display.
My data logger worked with the Adafruit board.
I can’t get it to work with the dev board and I have no idea why.
I have broken down my code (which comes from the Adafruit example) to the essentials.
#include "SPI.h"
#include "SdFat.h"
#include "Adafruit_SPIFlash.h"
#include "Adafruit_TinyUSB.h"
// Debug with FTDI (Serial0) or USBCDC (Serial)
#define DBG_SERIAL Serial
// ESP32 use same flash device that store code.
// Therefore there is no need to specify the SPI and SS
Adafruit_FlashTransport_ESP32 flashTransport;
Adafruit_SPIFlash flash(&flashTransport);
// file system object from SdFat
FatVolume fatfs;
// USB Mass Storage object
Adafruit_USBD_MSC usb_msc;
bool fs_formatted; // Check if flash is formatted
bool fs_changed; // Set to true when browser write to flash
// Setup
void setupMassStorage(void)
flash.begin();
// Set disk vendor id, product id and revision with string up to 8, 16, 4 characters respectively
usb_msc.setID("Adafruit", "External Flash", "1.0");
// Set callback
usb_msc.setReadWriteCallback(msc_read_cb, msc_write_cb, msc_flush_cb);
// Set disk size, block size should be 512 regardless of spi flash page size
usb_msc.setCapacity(flash.size()/512, 512);
// MSC is ready for read/write
fs_changed = false;
usb_msc.setReadyCallback(0, msc_ready_callback);
usb_msc.begin();
// Init file system on the flash
fs_formatted = fatfs.begin(&flash);
if ( !fs_formatted )
DBG_SERIAL.println("Failed to init files system, flash may not be formatted");
void refreshMassStorage(void)
fs_changed = true;
void setup()
#ifdef LED_BUILTIN
pinMode(LED_BUILTIN, OUTPUT);
DBG_SERIAL.begin(115200);
setupMassStorage();
// while ( !DBG_SERIAL ) delay(10); // wait for native usb
DBG_SERIAL.println("TinyUSB Mass Storage with ESP32 File Browser example");
DBG_SERIAL.print("JEDEC ID: 0x"); DBG_SERIAL.println(flash.getJEDECID(), HEX);
DBG_SERIAL.print("Flash size: "); DBG_SERIAL.print(flash.size() / 1024); DBG_SERIAL.println(" KB");
// Loop
void loop()
delay(2);//allow the cpu to switch to other tasks
// Callback invoked when received READ10 command.
// Copy disk's data to buffer (up to bufsize) and
// return number of copied bytes (must be multiple of block size)
int32_t msc_read_cb (uint32_t lba, void* buffer, uint32_t bufsize)
// Note: SPIFLash Bock API: readBlocks/writeBlocks/syncBlocks
// already include 4K sector caching internally. We don't need to cache it, yahhhh!!
return flash.readBlocks(lba, (uint8_t*) buffer, bufsize/512) ? bufsize : -1;
// Callback invoked when received WRITE10 command.
// Process data in buffer to disk's storage and
// return number of written bytes (must be multiple of block size)
int32_t msc_write_cb (uint32_t lba, uint8_t* buffer, uint32_t bufsize)
#ifdef LED_BUILTIN
return flash.writeBlocks(lba, buffer, bufsize/512) ? bufsize : -1;
// Callback invoked when WRITE10 command is completed (status received and accepted by host).
// used to flush any pending cache.
void msc_flush_cb (void)
// sync with flash
flash.syncBlocks();
// clear file system's cache to force refresh
fatfs.cacheClear();
#ifdef LED_BUILTIN
// Invoked when received Test Unit Ready command.
// return true allowing host to read/write this LUN e.g SD card inserted
bool msc_ready_callback(void)
// if fs has changed, mark unit as not ready temporarily to force PC to flush cache
bool ret = !fs_changed;
fs_changed = false;
return ret;
And here the ini File:
[env:esp32-s3-devkitm-1]
board = esp32-s3-devkitm-1
board_build.partitions = ffat.csv
adafruit/Adafruit TinyUSB Library@^3.1.3
adafruit/Adafruit SPIFlash@^4.3.4
build_unflags =
-DARDUINO_USB_MODE = 1
-DARDUINO_USB_CDC_ON_BOOT=1
-DUSE_TINYUSB=true
-DCDC_ENABLED=0
-DCORE_DEBUG_LEVEL=5
-DARDUINO_USB_MODE=0
; Serial Monitor options
My attempts:
- Adafruit TFT Rev - Arduino IDE: Code works. Internal memory is accessible via USB.
- dev board - Arduino IDE: This is where the problems start. The memory is recognised correctly. The code tells me the size of the internal memory in the terminal. USB does not work.
- Dev Board - Platformio: Immediate kernel panic.
Does anyone have an idea what the problem could be?
I am surprised that the example in the Arduino IDE works with the Adafruit board, but not with the Dev Board.
