Thank you for the response
Unfortunately, I can’t seem to get any board at all to work. I have tried many boards. I either receive this
output log: UnknownBoard: Unknown board ID ‘freenove_esp32_s3_wroom’
Or this
Error received upon uploading: A fatal error occurred: Failed to write to target RAM (result was 01070000: Operation timed out)’
The good news is, I believe I know what I am doing wrong. I think I was supposed to create a boards dir with a .json file inside it. Should the json file contain the configurations you sent me? I did not do that.
Current platformio.ini file:
; Redirecting...
[env:stable]
board = freenove_esp32_s3_wroom
GitHub - espressif/arduino-esp32: Arduino core for the ESP32
madhephaestus/ESP32Servo@^1.1.2
xreef/PCF8574 library@^2.3.7
-D ARDUINO_ESP32S3_DEV
-D ARDUINO_RUNNING_CORE=1
-D ARDUINO_EVENT_RUNNING_CORE=1
-D BOARD_HAS_PSRAM
upload_speed = 921600
board_build.arduino.ldscript = esp32s3_out.ld
board_build.arduino.partitions = default_8MB.csv
board_build.core = esp32
board_build.f_flash = 80000000L
board_build.flash_mode = dio
board_build.psram_type = opi
board_build.memory_type = dio_opi
board_build.hwids = 0X303A:0x1001
board_connectivity = wifi, bluetooth
board_debug.default_tool = esp-builtin
board_debug.onboard_tools = esp-builtin
board_debug.openocd_target = esp32s3.cfg
board_frameworks = arduino, espidf
board_name = Freenove ESP32-S3 WROOM N8R8 (8MB Flash / 8MB PSRAM)
board_upload.flash_size = 8MB
board_upload.maximum_ram_size = 327680
board_upload.maximum_size = 8388608
board_upload.require_upload_port = true
board_upload.speed = 921600
board_url = GitHub - Freenove/Freenove_ESP32_S3_WROOM_Board: Apply to FNK0085
board_vendor = Freenove
Thank you again!
