whenever i reset the mcu i take response from serial monitor like the below.
I have tried Tera term to see messages. but result is same. Serial commands isn’t working
Build:Feb 7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd5810,len:0x438
load:0x403cc710,len:0x90c
load:0x403ce710,len:0x2624
entry 0x403cc710
// put function declarations here:
int myFunction(int, int);
int result = myFunction(2, 3);
pinMode(30,OUTPUT);
Serial.println("hebele");
digitalWrite(30,HIGH);
delay(500);
digitalWrite(30,LOW);
delay(500);
// put function definitions here:
int myFunction(int x, int y) {
return x + y;
here is my code i have also changed monitor_speed to 115200 from platform.ini file
