I am using VSC + Platformio, connected to a ESP-Wrover-kit board… I setup the Hello_World project, and everything as per manuals/documentations…
I am on a Win10 platform using Visual Studio Code and already updated FT drivers with Zadig…
My platformio.ini :
[env:esp-wrover-kit]
board = esp-wrover-kit
framework = espidf
monitor_port = COM16
debug_tool = ft2232h
On the board I can compile, upload, run the code, look at serial monitor output, everything seems to work fine, but I can not debug it… As I start a debugging session, it appears like the CPU’s chain interrogation fails, and get a list of errors from then on… I have read a lot of stuff about this problems, and tested many solutions, but no way out… Could any1 give me a suggestion…?
Here the Debugger Log:
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
none separate
adapter speed: 20000 kHz
esp32 interrupt mask on
force hard breakpoints
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command “ftdi_tdo_sample_edge falling”
Info : clock speed 20000 kHz
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway…
Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
Warn : Bypassing JTAG setup events due to errors
Info : esp32: Debug controller was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32: Core was reset (pwrstat=0xFF, after clear 0xFF).
Error: cpu0: esp32_fetch_all_regs (line 171): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_fetch_all_regs (line 171): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_fetch_all_regs (line 171): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
and goes on…
Thanks
Kind Regards
Alex
