Sorry to join the crowd with these problems. I have read it all (I think).
I try to make a WEB-server. If index.html is embedded in main.cpp then everything works. Debugging and showing the page in a browser comes up as it should.
However when index.html (and CCS, JS script and some image) is placed in the root in separate file then first of all I get a 404 page not found, but also a debugging error.
Zadig int0 is set to WinUSB (v6.1.7600.16385) - but I repeatedly have to reset the USB port to get connection. When this debugging error occurs, it is of cause when this problem is fixed.
Remote communication error. Target disconnected.: No error.
And the usual
![image](https://community.platformio.org/uploads/default/original/2X/6/648ae1ef73a118cad61b00bbb63e3560c246849a.png)
My platformIO.ini:
[env:esp-wrover-kit]
board = esp-wrover-kit
ESP Async WebServer
arduino-libraries/Arduino_JSON @ 0.1.0
debug_speed = 500
build_type = debug
[platformio]
description = WEBserver intro
The WEB-server part of code is shown here:
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(SPIFFS, "/index.html", "text/html",false);
server.serveStatic("/", SPIFFS, "/");
// Start server
server.begin();
I am getting nuts over this - have tried everything else before coming here. I guess you are my last resort… ![:joy: :joy:](https://community.platformio.org/images/emoji/twitter/joy.png?v=12)
I if you work with SPIFFS you really want these files to be in the data/
directory of the project so that they can get packaged and uploaded to the microcontroller instead of in the project root. Or am I misunderstandnig?
When this error occurs, there should be more information in the Debug Console
tab of VSCode. What does it say there?
Is the full project uploaded somewhere for reference?
Hi - you are so fast… are you ever sleeping?
Yes the project loads completely without errors - not a handling or system error. Have even tried on another labtop. And yes the data directory is used.
Yes there are lots of information in the debug window… I have worked a lot more - may I share a snippet of code with you? I cannot read a SPIFFS file, and I think this is the real error - and maybee the subject should change to “cannot read SPIFFS file”
File fily = SPIFFS.open("/index.html",“r”);
if(!fily || fily.isDirectory()){
Serial.println(“− failed to open file for reading”);
Serial.println(“− read from file:”);
while(fily.available()){
Serial.write(file.read());
This code gets succesfully to this line: Serial.println(“− read from file:”);
and no more. It ends here.
Just post the project in a github repo for download.
Wow - never tried this - had to learn something. You only learn by doing mistakes.
I build my own SPIFF-test routine and I think I will improve on it - correct my mistakes.
However in this case I only learned that I had to reinstall VS-code, Python, platformIO and start all over from scratch. And I spend over 40 hours on this.
I don’t know - I think this is not a relevant issue for platformIO. I would recommend to remove it ![:joy: :joy:](https://community.platformio.org/images/emoji/twitter/joy.png?v=9)
