ESP32-WROVER-E problem debugging using ESP-Prog
Hi everyone!
First thanks for your ideas and support.
I am having troubles using the ESP-Prog for debugging.
In a simple blinking project worked one time (I didn’t try again) using the ESP-Prog and an ESP DevKit C.
I am using simple cables to connect GND and the 4 signals for debugging, not 3V3.
My project its composed of several files and libraries and unfortunately I didn’t have the ESP-Prog at the beginning, so i am using it for first time now.
The DEBUG CONSOLE spits SEVERAL lines that I don’t understand and are quite confusing, at least for me.
Here its almost all of the CONSOLE
undefinedC:\Users\jtantera\.platformio\packages\toolchain-xtensa-esp32\bin\xtensa-esp32-elf-gdb.exe: warning: Couldn't determine a path for the index cache directory.
Reading symbols from d:\Codigo\ESP32_Smart_iQ\ESP32_IMUCal_BTSerial\.pio\build\upesy_wrover\firmware.elf...
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger  v0.11.0-esp32-20220411 (2022-04-11-08:48)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp32-wrover.cfg is deprecated, and may be removed in a future release.
         If your board is ESP32-WROVER-KIT, use board/esp32-wrover-kit-1.8v.cfg instead.
DEPRECATED! use 'adapter speed' not 'adapter_khz'
adapter speed: 500 kHz
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : clock speed 500 kHz
Info : starting gdb server for esp32.cpu0 on pipe
Info : esp32.cpu0: Target halted, PC=0x40009081, debug_reason=00000000
Info : Set GDB target to 'esp32.cpu0'
Info : esp32.cpu1: Target halted, PC=0x400076DD, debug_reason=00000000
Warn : No symbols for FreeRTOS!
Info : esp32.cpu0: Target halted, PC=0x4009260E, debug_reason=00000001
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 105 KB
Info : Flash mapping 1: 0x30020 -> 0x400d0020, 713 KB
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 8192 KB
Info : Using flash bank 'esp32.cpu0.flash' size 8192 KB
Info : Using flash bank 'esp32.cpu0.irom' size 716 KB
Info : Using flash bank 'esp32.cpu0.drom' size 108 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
Warn : negative reply, retrying
0x40009081 in ?? ()
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
Info : esp32.cpu0: Target halted, PC=0x500000CF, debug_reason=00000000
Info : esp32.cpu0: Target halted, PC=0x40000400, debug_reason=00000000
Info : esp32.cpu1: Debug controller was reset.
Info : esp32.cpu1: Core was reset.
Info : esp32.cpu1: Target halted, PC=0x40000400, debug_reason=00000000
Info : Auto-detected flash bank 'esp32.cpu1.flash' size 8192 KB
Info : Using flash bank 'esp32.cpu1.flash' size 8192 KB
** Programming Started **
Info : PROF: Data transferred in 733.074 ms @ 27.2824 KB/s
** Programming Finished **
** Verify Started **
** Verified OK **
** Verified OK **
Info : PROF: Data transferred in 156.784 ms @ 25.5128 KB/s
** Verified OK **
** Verified OK **
Info : PROF: Data transferred in 296.005 ms @ 27.0266 KB/s
** Verified OK **
** Verified OK **
Info : PROF: Data transferred in 34148.8 ms @ 27.6437 KB/s
** Verified OK **
** Verified OK **
Temporary breakpoint 1 at 0x400d4360: file src/main.cpp, line 98.
PlatformIO: Resume the execution to `debug_init_break = tbreak setup`
PlatformIO: More configuration options -> https://bit.ly/pio-debug
Note: automatically using hardware breakpoints for read-only addresses.
Info : esp32.cpu0: Target halted, PC=0x40009073, debug_reason=00000000
Info : esp32.cpu1: Target halted, PC=0x400076E0, debug_reason=00000000
Program
 received signal SIGINT, Interrupt.
0x40009073 in ?? ()
pio_reset_run_target
Cannot execute this command while the target is running.
Use the "interrupt" command to stop the target
and then try again.
and then try again.
and then try again.
The platformio.ini:
[env:esp-wrover-kit]
board = esp-wrover-kit
upload_speed = 921000
	bblanchon/ArduinoJson@^6.19.4
	finani/ICM42688@^1.0.0
	stm32duino/STM32duino ST25DV@^1.1.0
adapter_speed = 20000
debug_speed = 500
upload_protocol = esp-prog
Near the end I paused the debugging and started again, and then stop it because never gets to the break point.
I believe that the problem it’s the memory map, I am setting something wrong and never get the right address, but I am quite new in this.
Any comment its welcome.
Thanks
