Hi All
Last week I received an ESP-PROG to allow me to use JTAG debugging with my ESP32 Dev Board.
To test the ESP-PROG board I created a new Arduino project in PlatformIO, loaded the BLINK code and all worked as expected. Build, Upload, debug, breakpoints…
Now this weekend as I am working on my real project code I am getting the following error in the debugger.
/builds/idf/crosstool-NG/.build/src/gdb-7.10/gdb/regcache.c:697: internal-error:
regcache_raw_read_unsigned: Assertion `regnum >= 0 && regnum < regcache->descr->nr_raw_registers' failed.
A problem internal to GDB has been detected, further debugging may prove unreliable.
Quit this debugging session?
When I close the project and open the BLINK test sketch it works fine. I have used the same PlateformIO.ini file for both the test BLINK and my project code.
Any suggestions on what I should be looking for here?
Thanks Dave
PlatformIO Core 5.1.1
Espressif32 3.3.1
VS Code Version: 1.60.0 (user setup)
Commit: e7d7e9a9348e6a8cc8c03f877d39cb72e5dfb1ff
Date: 2021-09-01T10:41:52.311Z
Electron: 13.1.8
Chrome: 91.0.4472.164
Node.js: 14.16.0
V8: 9.1.269.39-electron.0
OS: Windows_NT x64 10.0.19043
PlatformIO.ini
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
upload_port = com5
; ESP-PROG JTAG
debug_tool = esp-prog
board_debug.openocd_board = esp32-wrover-kit-1.8v.cfg
debug_speed = 12000
** note using the 1.8v cfg to fix the reboot loop problem with the GPIO12
