Using PlatformIO I can get programs that do not use wifi working on my esp32. When I try an example that uses wifi, however, the esp32 continuously reboots.
I have separately also installed the compiler and esp-idf directly from Espressif. With those I can get the examples with wifi working. If I use the exact same code (with sdkconfig translated into a .h file) in PlatformIO it continuously reboots again.
What am I doing wrong?
What is your platformio.ini
file?
The platformio.ini file is:
framework = espidf
upload_speed = 921600
The code is (with credentials filled in) the same as https://github.com/espressif/esp-idf-template/blob/master/main/main.c
I am not sure what that post tells me. I have updated framework-espidf via platformio to version 1.90.0.
I also tested it by making a copy of the “external” esp-idf files to ~/.platformio/packages/framework-espidf (keeping the package.json), but that gave a number of errors of missing files.
See my latest comment
It works, thanks!
