Hi Guys,
I’m sure this has been solved before, but I cannot find solution. And it’s related to library which needs to be either ignored and correct one replaced.
Below is my simple project to get things working.
Below is my unit:
https://www.aliexpress.com/item/32830221599.html
Basically, this project is pretty much copy-paste from Arduino IDE where the code actually gets connected to the mqtt broker. But here in PlatformIO. It does not get connect to the mqtt-broker.
I had to add the #include <WiFiSTA.h> in my code for it to at least connect to my wifi, otherwise it would not. Like I said, the code actually works perfect using Arduino IDE. Below it the build output.
PLATFORM: Espressif 32 1.12.0 > Espressif ESP32 Dev Module
Found 38 compatible libraries
|-- PubSubClient 2.7
|-- WiFi 1.2.7
| |-- SPI 1.0
|-- WiFi 1.0
Compiling .pio/build/esp32dev/src/main.cpp.o
Linking .pio/build/esp32dev/firmware.elf
Building .pio/build/esp32dev/firmware.bin
Retrieving maximum program size .pio/build/esp32dev/firmware.elf
Checking size .pio/build/esp32dev/firmware.elf
RAM: [= ] 12.0% (used 39392 bytes from 327680 bytes)
Flash: [===== ] 52.6% (used 689574 bytes from 1310720 bytes)
esptool.py v2.6
================================================================================================ [SUCCESS] Took 4.55 seconds ================================================================================================
