ESP32 WiFi.h not found
When I try to build I get the following error:
.platformio/packages/framework-arduinoespressif32/libraries/Ethernet/src/ETH.h:27:10: fatal error: WiFi.h: No such file or directory
Why is it not finding WiFi.h? it’s a part of the ESP32 platform.
What are you trying to build and what is the content of your platformio.ini?
I’m building my own code, a tester for lighting networks that can send or receive a universe of lighting data using various protocols.
platformio.ini:
[env]
lib_ldf_mode = chain+
	olikraus/U8g2@^2.34.18
	mathertel/RotaryEncoder@^1.5.3
	neu-rah/ArduinoMenu library@^4.21.4
	forkineye/ESPAsyncE131@^1.0.4
	rstephan/ArtnetWifi@^1.5.1
	hideakitai/ArtNet@^0.3.0
	neu-rah/streamFlow@0.0.0-alpha+sha.bf16ce8926
debug_build_flags =
	-O0 -ggdb3 -g3
	-D DEBUG
[env:ESP32]
Does this also happen with a blank new minimalistic WiFi sketch?
#include <WiFi.h>
    WiFi.begin("", "");
void loop() {}
Did some poking, looks like having lib_ldf_mode = chain+ is breaking it.
Here’s a minimal sketch that shows the problem:
platformio.ini
[env:ESP32]
main.cpp
#include <ETH.h>
	ETH.begin();
Sorry, I am not familiar with the Library Dependency Finder modes.
Did you choose this mode for a specific reason?
In the past I’ve had the dependency finder give me issues without chain+ mode (throwing errors because of header files that I didn’t even include), so now I use it by default, as the only difference from the default mode is that chain+ also evaluates preprocessor conditionals when deciding what files to build.
It shouldn’t affect whether or not a file can be found by my understanding.
I have never experienced such problems, so I have never needed chain+.
Yes, that is clear from the documentation.
Ethernet.h is dependent on WiFi.h
What I don’t understand is why the WiFi.h is not found. It is a built-in library.
Maybe @maxgerhardt can shed some light on this.
In case anyone has the same issue, I had to explicitly add it to lib_deps:
    WiFi
    WiFiClientSecure
    links2004/WebSockets@^2.6.1
In this case, something is broken.
Adding built-in libraries to lib_deps should be avoided as this is a source of other problems.
Try to reinstall the platform:
  • Close VS Code
  • Delete the folder C:\Users\<username>\.platformio\platforms\espressif32
  • Restart VS Code
  • Wait until PlatformIO finished all tasks (reinstalling the platform)
Heh, that did fix it. I don’t use VS Code, but I applied the same idea:
rm -r ~/.platformio/platforms/espressif32
pio run
Now it works fine with this simple config:
platform = espressif32 @ 6.10.0
upload_speed = 921600
Thanks!
Don’t use chain+ it is buggy and broken
