Trying to create a static array on PSRAM on a TTGO T8 board (TTGO T8 is not supported, compiling for a WROVER instead):
EXT_RAM_ATTR uint8_t arr[2500000];
Added the required build flags:
board = esp-wrover-kit
upload_port = COM4
-DBOARD_HAS_PSRAM
-DCONFIG_SPIRAM_CACHE_WORKAROUND (<<- with or without, doesn't matter)
-mfix-esp32-psram-cache-issue
But am still getting these errors:
c:/users/igor/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\firmware.elf section `.dram0.bss' will not fit in region `dram0_0_seg'
c:/users/igor/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: DRAM segment data does not fit.
c:/users/igor/.platformio/packages/toolchain-xtensa32/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: region `dram0_0_seg' overflowed by 7890920 bytes
esp_attr.h includes sdkconfig.h
What am I missing? This is just compilation, not trying to upload the thing.
