I’ve attempted multiple times over the past months to create a new project via platformio for an esp32 using espidf as the framework option.
In vscode I’m met with this error:
PIO Core Call Error: "The current working directory G:\\Dev\\bt\\esp32-bt will be used for the project.
The next files/directories have been created in G:\\Dev\\bt\\esp32-bt
\n\nError: Processing esp32dev (platform: espressif32; board: esp32dev; framework: espidf)
PLATFORM: Espressif 32 (3.0.0) > Espressif ESP32 Dev Module
- framework-espidf 3.40200.210118 (4.2.0)
- tool-cmake 3.16.4
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32 2.80400.210211 (8.4.0)
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
-- Configuring incomplete, errors occurred!
See also \"G:/Dev/bt/esp32-bt/.pio/build/esp32dev/CMakeFiles/CMakeOutput.log\".
See also \"G:/Dev/bt/esp32-bt/.pio/build/esp32dev/CMakeFiles/CMakeError.log\".
CMake Error at CMakeLists.txt:2 (include):
include could not find load file:
C:\\Users\\codex\\.platformio\\packages\\framework-espidf/tools/cmake/project.cmake
CMake Error at CMakeLists.txt:3 (project):
No CMAKE_C_COMPILER could be found.
Tell CMake where to find the compiler by setting either the environment
variable \"CC\" or the CMake cache entry CMAKE_C_COMPILER to the full path to
the compiler, or to the compiler name if it is in the PATH.
No CMAKE_CXX_COMPILER could be found.
variable \"CXX\" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
to the compiler, or to the compiler name if it is in the PATH.
========================== [FAILED] Took 2.20 seconds =========================="
In clion i’m met with this error in addition to this:
C:\Users\codex\AppData\Local\JetBrains\Toolbox\apps\CLion\ch-0\203.7148.70\bin\cmake\win\bin\cmake.exe -DCMAKE_BUILD_TYPE=esp32dev -G "CodeBlocks - MinGW Makefiles" G:\Dev\bt\bt-sandbox
-- The C compiler identification is GNU 8.1.0
-- The CXX compiler identification is GNU 8.1.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - failed
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - failed
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Configuring done
-- Generating done
-- Build files have been written to: G:/Dev/bt/bt-sandbox/cmake-build-esp32dev-mingw
Cannot resolve compiler path 'C:\Users\codex/.platformio/packages/toolchain-xtensa32@2.50200.80/bin/xtensa-esp32-elf-g++.exe'
When I restore or install the packaged, the version installs with the path difference of:
toolchain-xtensa32@2.50200.97
I’ve tried completely removing platformio, clearing the .platformio folder, clearing packages, reinstalling cmake, I’m running out of options. I don’t know where else to go from here, tried multiple ide options and through CLI, tried reinstalling, tried different systems. Is the current version of platformio bugged for this?
OS: Windows 10.
Does anyone have any ideas?
