I wrote code for the ESP32 with arduino framework using platformIO.
Now i want to switch off core 1 of ESP32 CPU. This is normally done by using a configuration option in “FreeRTOS menu” in ESP-IDF names CONFIG_FREERTOS_UNICORE
Meanwhile i understood that platformIO with framework arduino uses precompiled libraries, when i build my code for ESP32. That’s why the ESP32 build option “CONFIG_FREERTOS_UNICORE” in platformio.ini has no impact.
What can i do? I want to develop for ESP32 with platformIO, but i need a library which is not available for framework ESP32, only for framework arduino.
