I get errors as shown below when trying to compile the program below:
//esp32 i2c i2c_scanner
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_PWMServoDriver.h>
#define I2C_SDA 21
#define I2C_SCL 22
#define SERVOMIN 125 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX 575 // this is the 'maximum' pulse length count (out of 4096)
void setup()
Wire.begin();
Serial.begin(9600);
while (!Serial);
Serial.println("\nI2C Scanner");
board1.begin();
board1.setPWMFreq(60); // Analog servos run at ~60 Hz updates
board2.begin();
board2.setPWMFreq(60);
board3.begin();
board3.setPWMFreq(60);
void loop()
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknown error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
else
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
Compilation results in:
* Executing task in folder ESPSERVOs: platformio run --target upload --upload-port /dev/ttyACM0
Processing esp32dev (platform: espressif32 @ ^5.0.0; board: esp32dev; framework: arduino)
PLATFORM: Espressif 32 (5.4.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20006.221224 (2.0.6)
- tool-esptoolpy @ 1.40400.0 (4.4.0)
- tool-mkfatfs @ 2.0.1
Found 37 compatible libraries
|-- Adafruit PWM Servo Driver Library @ 3.0.1
|-- Adafruit BusIO @ 1.14.4
|-- Wire @ 2.0.0
|-- SPI @ 2.0.0
Linking .pio/build/esp32dev/firmware.elf
/home/utopistmaker/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/libFrameworkArduino.a(main.cpp.o):(.literal._Z8loopTaskPv+0x8): undefined reference to `setup()'
/home/utopistmaker/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/libFrameworkArduino.a(main.cpp.o):(.literal._Z8loopTaskPv+0xc): undefined reference to `loop()'
/home/utopistmaker/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pio/build/esp32dev/libFrameworkArduino.a(main.cpp.o): in function `loopTask(void*)':
/home/utopistmaker/.platformio/packages/framework-arduinoespressif32@3.20006.221224/cores/esp32/main.cpp:42: undefined reference to `setup()'
/home/utopistmaker/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /home/utopistmaker/.platformio/packages/framework-arduinoespressif32@3.20006.221224/cores/esp32/main.cpp:48: undefined reference to `loop()'
*** [.pio/build/esp32dev/firmware.elf] Error 1```
This is in an src folder which contains other programs that contain the similar dependencies all of which compile without errors. I have examined all the relevant posts on the community site (and many other places as well!) without finding a link to a possible reason or solution.
Any leads appreciated...
