I’m working with ESP32 boards for a project. I’ve been using a AZ-Delivery version for a while, and now I’m trying to use some Sparkfun ESP32 Things. I’ve run into two problems:
- the WiFi can’t connect. It can see all the relevant networks, but can’t make a connection
- it’s really hard to upload code over USB - I have to randomly press the reset button, and it works about 1 in 20 attempts.
Any ideas where to start debugging this? It’s a big enough codebase that a small example is hard, so I’m interested in what might be different between the ESP32Thing and other boards that causes these issues. I’ve tried setting the framework toespressif32@3.5.0 based on this post: ESP32 Doesnt connect to wifi AP - #11 by mrmaddotta but no luck so far.
Platformio.ini:
[platformio]
default_envs = test
[env]
ArduinoJson
FastLED
PubSubClient
LinkedList
;SPIFFS
Bounce2
;board_build.filesystem = spiffs
monitor_filters = send_on_enter
src_filter = +<*> -<.git/> -<.svn/> -<example/> -<examples/> -<test/> -<tests/> -<dev/> +<../examples/main-${PIOENV}.cpp>
board = az-delivery-devkit-v4
upload_port = /dev/cu.usbserial-0001
[env:default]
[env:test]
[env:test_more]
[env:joystick]
[env:joystick_led]
[env:dual_joystick_controller]
board = esp32thing
platform = espressif32@3.5.0
upload_port = /dev/cu.usbserial-DN02YS8G
monitor_port = /dev/cu.usbserial-DN02YS8G
upload_protocol = esptool
;upload_protocol = esp-prog
