PlatformIO Community
ESP32 SNTP function not defined error
I’m using Platformio compile/build ESP32 code. When I use the function “sntp_get_sync_interval” I get an error stating that the function is not defined. I do have the “esp_sntp.h” file included but that function is not defined in it. However, when I search online, I can find an “esp_sntp.h” file that does define that function. How can I tell whether Platformio is using the latest libraries? How do I get them updated?
Below are the contents of my platformio.ini file:
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
Thank you very much for any assistance.
Please see Question about IDF version of ESP platform version 3.4.0 - #2 by maxgerhardt
@maxgerhardt, thank you very much for your quick response. I was able to implement the suggested workaround and use Arduino-ESP32 version 2.0.2.
When PlatformIO officially releases version 2.0.2, how will we be notified?
Thanks again.
When https://github.com/platformio/platform-espressif32/issues/619 is closed and a new version above 3.4.0 appears on https://github.com/platformio/platform-espressif32/releases.
