now I use Serial.print() and Serial.println() at 9600 Bauds, I change the sdkconfig.“project_name”, and I still see strange characters displayed in the serial monitor.
Is there any other config file to change ?
Thank you in advance
Changing the sdkconfig
file in an Arduino-ESP32 project? That has no effect, since Arduino-ESP32 is based off a precompiled ESP-IDF version, changes to the sdkconfig
file are ignored.
You need to se the monitor_speed
value to the baud rate you are using.
If you are still having problems, post the complete platformio.ini
and code.
