Ok thanks,
I’ve created a project with esp32-s3-devkitc-1 and modify the .ini with the arduino framework.
I try to run the empty project after an platformio update I’ve many errors.
Processing waveshare_esp32_s3_zero (platform: platform = https://github.com/pioarduino/platform-espressif32/releases/download/55.03.35/platform-espressif32.zip; board: waveshare_esp32_s3_zero; framework: arduino)
AttributeError: Traceback (most recent call last):
File "C:\Users\Name\.platformio\penv\Lib\site-packages\platformio\__main__.py", line 103, in main
File "C:\Users\Name\.platformio\penv\Lib\site-packages\click\core.py", line 1157, in __call__
File "C:\Users\Name\.platformio\penv\Lib\site-packages\click\core.py", line 1078, in main
rv = self.invoke(ctx)
File "C:\Users\Name\.platformio\penv\Lib\site-packages\platformio\cli.py", line 85, in invoke
return super().invoke(ctx)
File "C:\Users\Name\.platformio\penv\Lib\site-packages\click\core.py", line 1688, in invoke
File "C:\Users\Name\.platformio\penv\Lib\site-packages\click\core.py", line 1434, in invoke
File "C:\Users\Name\.platformio\penv\Lib\site-packages\click\core.py", line 783, in invoke
File "C:\Users\Name\.platformio\penv\Lib\site-packages\click\decorators.py", line 33, in new_func
File "C:\Users\Name\.platformio\penv\Lib\site-packages\platformio\debug\cli.py", line 88, in cli
return helpers.predebug_project(
File "C:\Users\Name\.platformio\penv\Lib\site-packages\platformio\debug\helpers.py", line 102, in predebug_project
ctx.invoke(
File "C:\Users\Name\.platformio\penv\Lib\site-packages\platformio\run\cli.py", line 147, in cli
process_env(
File "C:\Users\Name\.platformio\penv\Lib\site-packages\platformio\run\cli.py", line 210, in process_env
).process()
File "C:\Users\Name\.platformio\penv\Lib\site-packages\platformio\run\processor.py", line 81, in process
install_project_env_dependencies(
File "C:\Users\Name\.platformio\penv\Lib\site-packages\platformio\package\commands\install.py", line 132, in install_project_env_dependencies
_install_project_env_platform(project_env, options),
File "C:\Users\Name\.platformio\penv\Lib\site-packages\platformio\package\commands\install.py", line 149, in _install_project_env_platform
PlatformPackageManager().install(
File "C:\Users\Name\.platformio\penv\Lib\site-packages\platformio\package\manager\platform.py", line 52, in install
p = PlatformFactory.new(pkg)
File "C:\Users\Name\.platformio\penv\Lib\site-packages\platformio\platform\factory.py", line 79, in new
platform_cls = getattr(
AttributeError: module 'platformio.platform.platform' has no attribute 'PlatformPlatform'
`python -m pip install -U platformio` command
