ESP32-S3 PIO firmware crashing while Arduino works
Hi everyone!
I’m trying to run TFT_eSPI library examples with ESP32-S3 in Arduino framework on PIO. The example code can be seen here: Colour_Wheel
When the library is initialized with tft.init(); the MCU bootloops like given below.
Rebooting...
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x42026ee6
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x4bc
load:0x403c9700,len:0xbd8
load:0x403cc700,len:0x2a0c
entry 0x403c98d0
Same library and examples work without issues on Arduino IDE. So I’m guessing that there is something set up wrong with my .platformio.ini file. Here is how it looks like.
[env:esp32-s3-devkitc-1]
board = esp32-s3-devkitc-1
monitor_rts = 0
monitor_dtr = 0
	-D ARDUINO_USB_CDC_ON_BOOT=1
	-D ARDUINO_USB_MSC_ON_BOOT=0
	-D ARDUINO_USB_DFU_ON_BOOT=0
lib_deps = bodmer/TFT_eSPI@^2.5.43
TFT_eSPI installing on PIO
If I configure the library like shown in these instructions the platformio.ini looks like this. But result is the same bootloop behavior.
[env:lolin_s3_mini]
board = lolin_s3_mini
monitor_rts = 0
monitor_dtr = 0
    ; TFT_eSPI library setting here (no need to edit library files):
    -D USER_SETUP_LOADED=1                       ; Set this settings as valid
    -D GC9A01_DRIVER=1                           ; Select ILI9163 driver
    -D TFT_WIDTH=240                             ; Set TFT size
    -D TFT_HEIGHT=240
    -D TFT_BACKLIGHT_ON=1                         ; Set backlight on level
    -D TFT_MISO=-1                                ; Define SPI pins
    -D TFT_MOSI=11
    -D TFT_SCLK=12
    -D TFT_CS=10
    -D TFT_DC=16                                  ; Data/Comand pin
    -D TFT_RST=6                                  ; Reset pin
    -D TFT_BL=17                                  ; Backlight pin
    -D TOUCH_CS=-1                                ; Touch chip select pin
    -D LOAD_GLCD=1                                ; Load Fonts
    -D SPI_FREQUENCY=80000000                     ; Set SPI frequency
When the library is not initialized I can work with this setups without any issues.
So far I’ve tried 2 different custom boards and a lolin s3 mini devkit but same issue persists. It feels like I’m missing something obvious. Can anyone point me in the some direction?
Thanks!
Maybe it’s too late, but for future users that can face a similar issue but with other libs. ESP32 has many pins that are used by internal processes in different scenarios. DONT use GPIO12 pin if there could be present a logical level.
As well if you use spifs or littlefs: SPI0/1: GPIO6-11 and GPIO16-17 are usually connected to the SPI flash and PSRAM integrated on the module and therefore should not be used for other purposes.
