Hi All,
I have a ESP32-S3 with 16MB Flash and 8MP PSRAM.
All was going well with basic Arduino sketches and then I added a encoder to GPIO pins 38,37,36 and then it stopped responding to my code. I used Arduino initially because of all the sample projects. I have done quite a few projects in PIO so not overly a newbie in this area.
Platformio.ini
[env:esp32]
board = esp32-s3-devkitc-1
; Specify velocity of serial monitor
; Specify the frequency of the CPU
; Specify the frequency of the FLASH
board_build.f_flash = 80000000L
; FLASH Partition table designated as 16MB
board_build.arduino.partitions = default_16MB.csv
; Specify the operating mode of FLASH and PSRAM
board_build.arduino.memory_type = qio_opi
; Predefined macro, enabling PSRAM
build_flags = -DBOARD_HAS_PSRAM
; Specify a FLASH capacity of 16MB
board_upload.flash_size = 16MB
main.cpp
Serial.println('Setup - Start');
// Stuff
Serial.println('Setup - Complete');
log_d("Total heap: %d", ESP.getHeapSize());
log_d("Free heap: %d", ESP.getFreeHeap());
log_d("Total PSRAM: %d", ESP.getPsramSize());
log_d("Free PSRAM: %d", ESP.getFreePsram());
delay(1000);
I don’t quite understand the problem yet. The output does not match the code and what does the rotary encoder have to do with it? Is the output correct if the encoder is not connected? If so, what does the output look like?
Oh, all you need to do is set the correct debug level in platformio.ini for log_d to work:
Hi All,
Sorry for the delay in coming back to this topic. Family issues.
The USB Uart is UART0.
If I use log_d(“Test”); it outputs.
If I use Serial.println(“fred”); it doesn’t.
If I use Serial.setDebugOutput(true); I get NO logging outputs. If I comment out this line, I get logging outputs. I can handle this idiosyncrasy.
Why does Serial.println(“fred”); not work??
This is in my main loop with a 1500mS delay
log_d(“Test”);
This is what I get on the monitor.
[474117][D][main.cpp:118] loop(): Test
[475617][D][main.cpp:118] loop(): Test
[477117][D][main.cpp:118] loop(): Test
Depending on the compiler flag ARDUINO_USB_CDC_ON_BOOT you must use either Serial or Serial0 to output via UART 0 (RX/TX pins / onboard Serial to USB chip).
