Hello Max,
according to my order at Mouser you were right:
ESP32-S3-DevKitC-1-N32R16V
On th metal shielding I can read âWroom2â.
I donât connect any GPIO pin, cause my intention is to build an USB boot keyboard. It should control a MixPre box by Sound Systems and it turns out, that this box is a diva. It works with hp and Logitech kbds, but fails with my module. I found out, that the keyboards exposing a Composite HID device with TWO logical keyboard devices. At this point i failed with Arduino IDE and framework and try now the VSC and PIO way of life.
The module works fine with Arduino IDE, blinky running, ESP-NOW (as receiver) running everything within minutes. Debugging doesntât work, the S3 should have a embedded debug intrface, but I canât get it to work. On th other habd, it looks like tzhe native USB socket is used for debugging, and this sockt I ned exclusivly for my project, so debugging with led, port signals & scope or println is the only way to go.
I also have an Atmel-ICE or I can buy other JTAG box, no problem, if there is some guaranteee, that VSC with PlatformIO can use it somehow. I am a newbee to PatformIO, so nothing is easy.
I used AtmlStudio and VisualStudio for 15 years, so mbedded programming is not new for my, but the tools are.
The board still runs with Arduino IDE, no damage for now:
Sketch uses 404942 bytes (12%) of program storage space. Maximum is 3145728 bytes.
Global variables use 52052 bytes (15%) of dynamic memory, leaving 275628 bytes for local variables. Maximum is 327680 bytes.
esptool v5.2.0
Serial port COM16:
Connecting....
Connected to ESP32-S3 on COM16:
Chip type: ESP32-S3 (QFN56) (revision v0.2)
Features: Wi-Fi, BT 5 (LE), Dual Core + LP Core, 240MHz, Embedded PSRAM 16MB (AP_1v8)
Crystal frequency: 40MHz
MAC: 90:e5:b1:d5:42:34
Uploading stub flasher...
Running stub flasher...
Stub flasher running.
Changing baud rate to 921600...
Changed.
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00004fff...
Compressed 18736 bytes to 12224...
Writing at 0x00000000 [ ] 0.0% 0/12224 bytes...
Writing at 0x00004930 [==============================] 100.0% 12224/12224 bytes...
Wrote 18736 bytes (12224 compressed) at 0x00000000 in 0.3 seconds (441.3 kbit/s).
Verifying written data...
Hash of data verified.
Compressed 3072 bytes to 144...
Writing at 0x00008000 [ ] 0.0% 0/144 bytes...
Writing at 0x00008c00 [==============================] 100.0% 144/144 bytes...
Wrote 3072 bytes (144 compressed) at 0x00008000 in 0.0 seconds (588.8 kbit/s).
Writing at 0x0000e000 [ ] 0.0% 0/47 bytes...
Writing at 0x00010000 [==============================] 100.0% 47/47 bytes...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (911.5 kbit/s).
Flash will be erased from 0x00010000 to 0x00072fff...
Compressed 405088 bytes to 231496...
Thats the output befor upload of my sketch starts, only to document the different partionis.
And here is the debugger output of your code:
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
Octal Flash Mode Enabled
For OPI Flash, Use Default Flash Boot Mode
mode:SLOW_RD, clock div:1
load:0x3fce2820,len:0xfb0
load:0x403c8700,len:0xaf4
load:0x403cb700,len:0x2e34
entry 0x403c8898
=========== Before Setup Start ===========
Chip Info:
Model : ESP32-S3
Package : 0
Revision : 0.02
Cores : 2
CPU Frequency : 240 MHz
XTAL Frequency : 40 MHz
Features Bitfield : 0x00000012
Embedded Flash : No
Embedded PSRAM : No
2.4GHz WiFi : Yes
Classic BT : No
BT Low Energy : Yes
IEEE 802.15.4 : No
INTERNAL Memory Info:
Total Size : 344264 B ( 336.2 KB)
Free Bytes : 311720 B ( 304.4 KB)
Allocated Bytes : 28132 B ( 27.5 KB)
Minimum Free Bytes: 306572 B ( 299.4 KB)
Largest Free Block: 278516 B ( 272.0 KB)
SPIRAM Memory Info:
Total Size : 16777216 B (16384.0 KB)
Free Bytes : 16774572 B (16381.4 KB)
Allocated Bytes : 136 B ( 0.1 KB)
Minimum Free Bytes: 16774572 B (16381.4 KB)
Largest Free Block: 16515060 B (16128.0 KB)
Bus Mode : OPI
Flash Info:
Chip Size : 33554432B (32 MB)
Block Size : 65536B ( 64.0 KB)
Sector Size : 4096B ( 4.0 KB)
Page Size : 256B ( 0.2 KB)
Bus Speed : 80 MHz
Flash Frequency : 80 MHz (source: 160 MHz, divider: 2)
Bus Mode : OPI
Partitions Info:
nvs : addr: 0x00009000, size: 20.0 KB, type: DATA, subtype: NVS
otadata : addr: 0x0000E000, size: 8.0 KB, type: DATA, subtype: OTA
app0 : addr: 0x00010000, size: 3072.0 KB, type: APP, subtype: OTA_0
app1 : addr: 0x00310000, size: 3072.0 KB, type: APP, subtype: OTA_1
ffat : addr: 0x00610000, size: 10112.0 KB, type: DATA, subtype: FAT
coredump : addr: 0x00FF0000, size: 64.0 KB, type: DATA, subtype: COREDUMP
Software Info:
Compile Date/Time : Apr 25 2026 13:56:41
Compile Host OS : windows
ESP-IDF Version : v5.5.4
Arduino Version : 3.3.8
Board Info:
Arduino Board : ESP32S3_DEV
Arduino Variant : esp32s3
Arduino FQBN : esp32:esp32:esp32s3-octal:UploadSpeed=921600,USBMode=default,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=opi,FlashSize=16M,PartitionScheme=app3M_fat9M_16MB,DebugLevel=debug,PSRAM=opi,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=bridge
============ Before Setup End ============
[ 363][D][esp32-hal-uart.c:845] uartSetPins(): Attaching pin 44 to UART0 as RX
[ 370][D][esp32-hal-uart.c:849] uartSetPins(): Attaching pin 43 to UART0 as TX
=========== After Setup Start ============
Free Bytes : 310916 B ( 303.6 KB)
Allocated Bytes : 28776 B ( 28.1 KB)
Minimum Free Bytes: 305768 B ( 298.6 KB)
SPIRAM Memory Info:
Free Bytes : 16772968 B (16379.9 KB)
Allocated Bytes : 1612 B ( 1.6 KB)
Minimum Free Bytes: 16772968 B (16379.9 KB)
GPIO Info:
GPIO : BUS_TYPE[bus/unit][chan]
43 : UART_TX[0]
44 : UART_RX[0]
============ After Setup End =============
Sorry, I was blocked again, a new user canât give more than two replays a day âŚ.. sorry for that delay.
