I have a project that uses ESP32-S3-Touch-LCD-3.5B from Waveshare with a display driver AXS15231.
The project compiles and runs perfectly in Arduino IDE (no flicker), but when I build the exact same code in PlatformIO, the display flickers heavily.
I made sure that:
- ESP32 Arduino core version is the same: 3.2.1
- GFX Library version is the same: 1.6.1 (moononournation/GFX Library for Arduino)
- Board definition: esp32-s3-devkitc1-n16r8
Still, only the PlatformIO build shows flickering.
PlatformIO Configuration:
Here is my current platformio.ini:
[env:esp32-s3-devkitc1-n16r8]
platform = https://github.com/pioarduino/platform-espressif32/releases/download/54.03.21-2/platform-espressif32.zip
board = esp32-s3-devkitc1-n16r8
board_build.arduino.memory_type = qio_opi
board_build.partitions = app3M_fat9M_16MB.csv
moononournation/GFX Library for Arduino@^1.6.1
-DF_CPU=240000000L
-DARDUINO_ESP32S3_DEV
-DARDUINO_ARCH_ESP32
-DARDUINO_HOST_OS=\"windows\"
-DARDUINO_FQBN=\"esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=16M,PartitionScheme=app3M_fat9M_16MB,DebugLevel=debug,PSRAM=opi,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"
-DARDUINO_RUNNING_CORE=1
-DARDUINO_EVENT_RUNNING_CORE=1
-DBOARD_HAS_PSRAM
-DARDUINO_USB_MODE=1
-DARDUINO_USB_CDC_ON_BOOT=1
-DARDUINO_USB_MSC_ON_BOOT=0
-DARDUINO_USB_DFU_ON_BOOT=0
-DCORE_DEBUG_LEVEL=4
What I already tried:
- Matched all build flags with Arduino IDE
- Tried both
board_build.arduino.memory_type = qio_opiandqio_qspi - Disabled PSRAM heap override with
-DARDUINO_DISABLE_PSRAM_HEAP
Nothing solved the flickering.
Why does the display flicker only when compiled with PlatformIO?
