PgXme
June 28, 2022, 8:54am
#1
I’m facing a problem when I use the ESP32-S2, Arduino framework in PlatformIO. The same procedure works fine with an ESP32.
Code:
Serial.println(“Hello”);
delay(200);
ini
[env:adafruit_metro_esp32s2]
board = adafruit_metro_esp32s2
After build and upload, I reset the ESP32-S2 and see the boot sequence, but no string as defined in the loop
Boot sequence:
ESP-ROM:esp32s2-rc4-20191025
Build:Oct 25 2019
rst:0x1 (POWERON),boot:0x9 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3ffe6100,len:0x17c0
load:0x4004c000,len:0xfd4
load:0x40050000,len:0x2fa0
entry 0x4004c340
␛[0;32mI (21) boot: ESP-IDF v4.3.1-480-g233dc30fb1 2nd stage bootloader␛[0m
␛[0;32mI (21) boot: compile time 10:09:11␛[0m
␛[0;32mI (21) boot: chip revision: 0␛[0m
␛[0;32mI (25) qio_mode: Enabling default flash chip QIO␛[0m
␛[0;32mI (30) boot.esp32s2: SPI Speed : 80MHz␛[0m
␛[0;32mI (35) boot.esp32s2: SPI Mode : QIO␛[0m
␛[0;32mI (40) boot.esp32s2: SPI Flash Size : 4MB␛[0m
␛[0;32mI (45) boot: Enabling RNG early entropy source...␛[0m
␛[0;32mI (50) boot: Partition Table:␛[0m
␛[0;32mI (54) boot: ## Label Usage Type ST Offset Length␛[0m
␛[0;32mI (61) boot: 0 nvs WiFi data 01 02 00009000 00005000␛[0m
␛[0;32mI (68) boot: 1 otadata OTA data 01 00 0000e000 00002000␛[0m
␛[0;32mI (76) boot: 2 ota_0 OTA app 00 10 00010000 00160000␛[0m
␛[0;32mI (83) boot: 3 ota_1 OTA app 00 11 00170000 00160000␛[0m
␛[0;32mI (91) boot: 4 uf2 factory app 00 00 002d0000 00040000␛[0m
␛[0;32mI (98) boot: 5 ffat Unknown data 01 81 00310000 000f0000␛[0m
␛[0;32mI (106) boot: End of partition table␛[0m
␛[0;32mI (110) boot: Detect double reset using RC on GPIO 38 to enter UF2 bootloader␛[0m
␛[0;32mI (118) esp_image: segment 0: paddr=002d0020 vaddr=3f000020 size=02f78h ( 12152) map␛[0m
␛[0;32mI (129) esp_image: segment 1: paddr=002d2fa0 vaddr=3ffbca30 size=01bd0h ( 7120) load␛[0m
␛[0;32mI (136) esp_image: segment 2: paddr=002d4b78 vaddr=40022000 size=0aa2ch ( 43564) load␛[0m
␛[0;32mI (153) esp_image: segment 3: paddr=002df5ac vaddr=50000000 size=00010h ( 16) load␛[0m
␛[0;32mI (153) esp_image: segment 4: paddr=002df5c4 vaddr=00000000 size=00a54h ( 2644) ␛[0m
␛[0;32mI (160) esp_image: segment 5: paddr=002e0020 vaddr=40080020 size=10abch ( 68284) map␛[0m
␛[0;32mI (185) boot: Loaded app from partition at offset 0x2d0000␛[0m
␛[0;32mI (185) boot: Disabling RNG early entropy source...␛[0m
␛[0;32mI (197) c���␆�f�~␀�␘����Սѥ���cache : size 8KB, 4Ways, cache line size 32Byte␛[0m
␛[0;32mI (198) cpu_start: Pro cpu up.␛[0m
␛[0;32mI (211) cpu_start: Pro cpu start user code␛[0m
␛[0;32mI (211) cpu_start: cpu freq: 160000000␛[0m
␛[0;32mI (211) cpu_start: Application information:␛[0m
␛[0;32mI (216) cpu_start: Project name: tinyuf2␛[0m
␛[0;32mI (221) cpu_start: App version: 0.6.2␛[0m
␛[0;32mI (225) cpu_start: Compile time: Dec 8 2021 10:09:05␛[0m
␛[0;32mI (231) cpu_start: ELF file SHA256: bcef9f58e8eb2367...␛[0m
␛[0;32mI (237) cpu_start: ESP-IDF: v4.3.1-480-g233dc30fb1␛[0m
␛[0;32mI (244) heap_init: Initializing. RAM available for dynamic allocation:␛[0m
␛[0;32mI (251) heap_init: At 3FF9E000 len 00002000 (8 KiB): RTCRAM␛[0m
␛[0;32mI (257) heap_init: At 3FFD1B88 len 0002A478 (169 KiB): DRAM␛[0m
␛[0;32mI (263) heap_init: At 3FFFC000 len 00003A10 (14 KiB): DRAM␛[0m
␛[0;32mI (270) spi_flash: detected chip: generic␛[0m
␛[0;32mI (274) spi_flash: flash io: qio␛[0m
␛[0;32mI (278) cpu_start: Starting scheduler on PRO CPU.␛[0m
Any help would be appreciated
Under which settings does the above sketch work in the Arduino IDE?
PgXme
June 28, 2022, 9:32am
#3
I compared it with ESP32, which works fine in PlatformIO Arduino framework. I don’t use Arduino IDE
The same code produce the expected serial output:
rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:12784
load:0x40080400,len:3032
entry 0x400805e4
Hello
Hello
Hello
Hello
Hello
Hello
Ini has been modified to:
;board = adafruit_metro_esp32s2
board = esp-wrover-kit
Very strange… repeated the same code with the ESP32-S2 (board = adafruit_metro_esp32s2 in ini) and receive now the following output:
entry 0x4004c340
␛[0;32mI (24) boot: ESP-IDF v4.3.1-480-g233dc30fb1 2nd stage bootloader␛[0m
␛[0;32mI (24) boot: compile time 10:09:11␛[0m
␛[0;32mI (24) boot: chip revision: 0␛[0m
␛[0;31mE (28) boot_comm: mismatch chip ID, expected 2, found 0␛[0m
Build:Oct 25 2019
rst:0x3 (RTC_SW_SYS_RST),boot:0x9 (SPI_FAST_FLASH_BOOT)
Saved PC:0x40051636
SPIWP:0xee
entry 0x4004c340
Build:Oct 25 2019
But that’s expected, flashig an ESP32 firmwre on an ESP32S2 is just not compatible.
Which exact development board do you have?
PgXme
June 28, 2022, 10:00am
#5
the board type has been changed to the ESP32S2 in ini… or is that not enough?
It is a custom board with an ESP32-S2-WROVER
Do you read the serial output via a USB-to-serial chip on the board (like a CH340) or does that come from the ESP32-S2’s USB port itself?
Remember when you are using this, the board definition says
so Serial
output will go to the USB-serial device created on the ESP32S2’s USB port.
If that does not apply to you and you want it out via hardware UART, use board = esp32-s2-saola-1
instead, that one doesn’t have it…
PgXme
June 28, 2022, 10:11am
#8
ok, I changed the ini, but the problem is still the same…
the same problem with a new created project:
[env:esp32-s2-saola-1]
But what’s the answer to this question
PgXme
June 28, 2022, 10:22am
#10
I use a CP210X USB2UART device connected to the ESP32-S2 RXD0/TXD0
In addition the same behaviour is with esp-prog with usage of the UART interface (not the Jtag)
PgXme:
ESP32-S2 RXD0/TXD0
Then per https://cdn-reichelt.de/documents/datenblatt/A200/ESP32-S2-WROVER_ESP32-S2-WROVER-I_DATASHEET_EN.pdf page 11 those pins should be TX = IO43 and RX=IO44.
which means wthat when you select board = esp32-s2-saola-1
which gives you
"extra_flags": "-DARDUINO_ESP32S2_DEV",
"f_cpu": "240000000L",
"f_flash": "80000000L",
"flash_mode": "qio",
"mcu": "esp32s2",
"variant": "esp32s2"
which maps to this variant and UART pins
it should be correct for pins at least.
Can you change the code to blink an LED instead of trying to send something via UART?
Use
* Blink
* Turns on an LED on for one second,
* then off for one second, repeatedly.
// Set LED_BUILTIN if it is not defined by Arduino framework
#ifndef LED_BUILTIN
#define LED_BUILTIN 2
void setup()
// initialize LED digital pin as an output.
pinMode(LED_BUILTIN, OUTPUT);
void loop()
This file has been truncated. show original
on an arbitrary free IO and see if the voltage changes at that pin at all.
If it does, it does enter loop()
and when you have board = esp32-s2-saola-1
selected but still see no output it could because of a hardware fault (TX/RX swapped or whatever)
PgXme
June 29, 2022, 9:03am
#12
it seems that there was a problem with the prototype board. I have connected another one and the code works fine with the serial output for the ESP32-S2.
Many thanks for your support @maxgerhardt
