I plan to use the newer esp32-s2 in future (LILYGO® T8 V1.7.1 ESP32 Modul 8MB PSRAM TF KARTE 3D Antenne WiFi Drahtlose Bluetooth Entwicklung Board für Arduino Micropython|antenna wifi|cards 3dcard card - AliExpress - Lilygo T8 V1.7.1) for some of my projects, but currently I am stuck in the first steps. The S2 isn’t really well supported by platformio so far. I thought after 2 y on the market the chip would work out of the box, but well…
So I tried to use some of the configuration variants based on attempts of others, but without luck
[env:Lily-esp32-t8]
platform_packages =
toolchain-xtensa32s2
framework-arduinoespressif32@https://github.com/espressif/arduino-esp32.git#master
platformio/tool-esptoolpy@~1.30100
board = esp32doit-devkit-v1
board_build.mcu = esp32s2
;board_build.partitions = huge_app.csv
build_unflags =
-DARDUINO_ESP32_DEV
-DARDUINO_VARIANT="esp32"
-DARDUINO_MAGTAG29_ESP32S2
; -DARDUINO_SERIAL_PORT=1
; -DARDUINO_VARIANT="adafruit_magtag29_esp32s2"
-DARDUINO_VARIANT="esp32s2"
-DBOARD_HAS_PSRAM
upload_port = COM11
Even when using a blank main.cpp like:
I get the following error log:
Processing Lily-esp32-t8 (framework: arduino; platform: espressif32; board: esp32doit-devkit-v1)
-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (3.5.0) > DOIT ESP32 DEVKIT V1
HARDWARE: ESP32S2 240MHz, 320KB RAM, 4MB Flash
- framework-arduinoespressif32 0.0.0+sha.c4954dd
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-riscv-esp 1.80400.0 (8.4.0)
- toolchain-xtensa32s2 1.80400.210211 (8.4.0)
Found 31 compatible libraries
Compiling .pio\build\Lily-esp32-t8\src\main.cpp.o
Generating partitions .pio\build\Lily-esp32-t8\partitions.bin
Archiving .pio\build\Lily-esp32-t8\libFrameworkArduinoVariant.a
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\FirmwareMSC.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\HWCDC.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\Print.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\USB.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\USBCDC.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\USBMSC.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\WString.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\base64.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-i2c-slave.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-tinyusb.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\firmware_msc_fat.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\main.cpp.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\Lily-esp32-t8\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\Lily-esp32-t8\libFrameworkArduino.a
Linking .pio\build\Lily-esp32-t8\firmware.elf
c:/users/becks/.platformio/packages/toolchain-xtensa32s2/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld.exe: final link failed: bad value
*** [.pio\build\Lily-esp32-t8\firmware.elf] Error 1
================================================================================== [FAILED] Took 8.39 seconds ==================================================================================
any ideas how to fix that?
