Hello
I am working on firmware using Ai-thinker esp32-s.
I am testing the upload with only very simple code.
At this point, the following error occurs:
Processing esp32cam (platform: espressif32; board: esp32cam; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32cam.html
PLATFORM: Espressif 32 (3.5.0) > AI Thinker ESP32-CAM
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- tool-openocd-esp32 2.1000.20210721 (10.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 29 compatible libraries
|-- <ESP32 AnalogWrite> 0.2.0
Retrieving maximum program size .pio\build\esp32cam\firmware.elf
Checking size .pio\build\esp32cam\firmware.elf
RAM: [ ] 4.3% (used 14076 bytes from 327680 bytes)
Flash: [= ] 8.9% (used 278846 bytes from 3145728 bytes)
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Use manually specified: COM3
Uploading .pio\build\esp32cam\firmware.bin
esptool.py v3.1
Serial port COM3
Connecting........_____....._____....._____....._____....._____
Chip is ESP32-D0WD (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 8c:ce:4e:9a:33:98
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Warning: Could not auto-detect Flash size (FlashID=0x0, SizeID=0x0), defaulting to 4MB
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00010000 to 0x00054fff...
Compressed 17104 bytes to 11191...
Writing at 0x00001000... (100 %)
A fatal error occurred: Timed out waiting for packet header
*** [upload] Error 2
========================================================================================================================== [FAILED] Took 28.94 seconds ==========================================================================================================================The terminal process "C:\Users\ilk48\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
commonly
It starts with Writing at 0x00001000… (07 %).
I got the first message
It is displayed as 100% like Writing at 0x00001000… (100 %).
And Time out is displayed.
I can’t predict what kind of problem there is.
I think it’s a problem with PlatformIO.
If anyone knows what the problem is, please help.
