So I’m concerned about the amount of memory my program is taking up on my ESP32. There are probably a myriad of ways I could optimize the code.
Output is a really long list of compilations and dependencies:
PLATFORM: Espressif 32 (54.3.20) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.2.0
- framework-arduinoespressif32-libs @ 5.4.0+sha.2f7dcd862a
- tool-esptoolpy @ 4.8.9
- tool-mklittlefs @ 3.2.0
- tool-riscv32-esp-elf-gdb @ 14.2.0+20240403
- tool-xtensa-esp-elf-gdb @ 14.2.0+20240403
- toolchain-xtensa-esp-elf @ 14.2.0+20241119
Found 47 compatible libraries
|-- ArduinoJson @ 7.4.1
|-- NTPClient @ 3.2.1
|-- esp32wifi
|-- FS @ 3.2.0
|-- LittleFS @ 3.2.0
|-- littlefs_funcs
|-- SD @ 3.2.0
|-- sensor_read_json
|-- SPI @ 3.2.0
|-- write_read_json
|-- BluetoothSerial @ 3.2.0
|-- Preferences @ 3.2.0
|-- WiFi @ 3.2.0
Compiling .pio\build\esp32dev\src\main.cpp.o
Building .pio\build\esp32dev\bootloader.bin
Generating partitions .pio\build\esp32dev\partitions.bin
Compiling .pio\build\esp32dev\libf37\NTPClient\NTPClient.cpp.o
Compiling .pio\build\esp32dev\libb51\Network\NetworkClient.cpp.o
Compiling .pio\build\esp32dev\libb51\Network\NetworkEvents.cpp.o
Compiling .pio\build\esp32dev\libb51\Network\NetworkInterface.cpp.o
Compiling .pio\build\esp32dev\libb51\Network\NetworkManager.cpp.o
Compiling .pio\build\esp32dev\libb51\Network\NetworkServer.cpp.o
esptool.py v4.8.9
Creating esp32 image...
Merged 2 ELF sections
Compiling .pio\build\esp32dev\libb51\Network\NetworkUdp.cpp.o
Archiving .pio\build\esp32dev\libf37\libNTPClient.a
Compiling .pio\build\esp32dev\lib0bb\WiFi\AP.cpp.o
Compiling .pio\build\esp32dev\lib0bb\WiFi\STA.cpp.o
Compiling .pio\build\esp32dev\lib0bb\WiFi\WiFi.cpp.o
Compiling .pio\build\esp32dev\lib0bb\WiFi\WiFiAP.cpp.o
Compiling .pio\build\esp32dev\lib0bb\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp32dev\lib0bb\WiFi\WiFiMulti.cpp.o
Archiving .pio\build\esp32dev\libb51\libNetwork.a
Compiling .pio\build\esp32dev\lib0bb\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\esp32dev\lib0bb\WiFi\WiFiScan.cpp.o
Compiling .pio\build\esp32dev\libd69\esp32wifi\ESP32WifiShowNetworks.cpp.o
Compiling .pio\build\esp32dev\lib888\FS\FS.cpp.o
Compiling .pio\build\esp32dev\lib888\FS\vfs_api.cpp.o
Compiling .pio\build\esp32dev\lib486\LittleFS\LittleFS.cpp.o
Compiling .pio\build\esp32dev\libc7e\littlefs_funcs\littlefs_funcs.cpp.o
Compiling .pio\build\esp32dev\libdd3\SPI\SPI.cpp.o
Compiling .pio\build\esp32dev\lib4a2\SD\SD.cpp.o
Archiving .pio\build\esp32dev\lib0bb\libWiFi.a
Compiling .pio\build\esp32dev\lib4a2\SD\sd_diskio.cpp.o
Archiving .pio\build\esp32dev\libd69\libesp32wifi.a
Compiling .pio\build\esp32dev\lib4a2\SD\sd_diskio_crc.c.o
Archiving .pio\build\esp32dev\lib486\libLittleFS.a
Archiving .pio\build\esp32dev\libdd3\libSPI.a
Compiling .pio\build\esp32dev\libc1a\sensor_read_json\sensor_read.cpp.o
Compiling .pio\build\esp32dev\libddc\write_read_json\write_read_json.cpp.o
Archiving .pio\build\esp32dev\lib888\libFS.a
Compiling .pio\build\esp32dev\lib62b\BluetoothSerial\BTAddress.cpp.o
Compiling .pio\build\esp32dev\lib62b\BluetoothSerial\BTAdvertisedDeviceSet.cpp.o
Compiling .pio\build\esp32dev\lib62b\BluetoothSerial\BTScanResultsSet.cpp.o
Compiling .pio\build\esp32dev\lib62b\BluetoothSerial\BluetoothSerial.cpp.o
Archiving .pio\build\esp32dev\libc7e\liblittlefs_funcs.a
Compiling .pio\build\esp32dev\libdd9\Preferences\Preferences.cpp.o
Archiving .pio\build\esp32dev\lib4a2\libSD.a
Compiling .pio\build\esp32dev\FrameworkArduino\ColorFormat.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\Esp.cpp.o
Archiving .pio\build\esp32dev\libc1a\libsensor_read_json.a
Compiling .pio\build\esp32dev\FrameworkArduino\FirmwareMSC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\HEXBuilder.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\HWCDC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\IPAddress.cpp.o
Archiving .pio\build\esp32dev\libdd9\libPreferences.a
Compiling .pio\build\esp32dev\FrameworkArduino\MD5Builder.cpp.o
Archiving .pio\build\esp32dev\lib62b\libBluetoothSerial.a
Archiving .pio\build\esp32dev\libddc\libwrite_read_json.a
Compiling .pio\build\esp32dev\FrameworkArduino\MacAddress.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Print.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\SHA1Builder.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\USB.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\USBCDC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\USBMSC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\chip-debug-report.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-i2c-ng.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-i2c-slave.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-periman.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-rgb-led.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-tinyusb.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-touch-ng.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\firmware_msc_fat.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\freertos_stats.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\main.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\esp32dev\libFrameworkArduino.a
Linking .pio\build\esp32dev\firmware.elf
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [== ] 18.6% (used 61092 bytes from 327680 bytes)
Flash: [===Error: The program size (1710954 bytes) is greater than maximum allowed (1310720 bytes)
==*** [checkprogsize] Explicit exit, status 1
=====] 130.5% (used 1710954 bytes from 1310720 bytes)
I didn’t expect the program to be this intensive and I’m not even halfway done writing the code.
Any tips? Are there tools that can help optimize or remove unused packages? Or perhaps it could be the partitions - how can I check the current partition size and possibly adjust them to allow for more room for my program?
I am using the devkit in this box (it has pre-soldered pins so it works much better for SD capabilities & whatnot).
Amazon.com: LAFVIN Basic Starter Kit for ESP32 ESP-32S WiFi I OT Development Board with Tutorial Compatible with Arduino IDE : Electronics
I believe it’s 4 MB flash but i can’t quite verify…
Also when I calculate size I get the following:
Calculating size .pio\build\esp32dev\firmware.elf
text data bss dec hex filename
1487089 247100 34329 1768518 1afc46 .pio\build\esp32dev\firmware.elf
