Hello All,Im getting this error while linking in my esp32 on platform io.
PLATFORM: Espressif 32 (3.5.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 34 compatible libraries
|-- <Adafruit BusIO> 1.11.1
| |-- <Wire> 1.0.1
| |-- <SPI> 1.0
|-- <Adafruit GFX Library> 1.10.13
| | |-- <Wire> 1.0.1
| | |-- <SPI> 1.0
| |-- <Wire> 1.0.1
| |-- <SPI> 1.0
|-- <Adafruit MPU6050> 2.0.6
| | |-- <Wire> 1.0.1
| | |-- <SPI> 1.0
| |-- <Wire> 1.0.1
| |-- <SPI> 1.0
| |-- <Adafruit Unified Sensor> 1.1.4
|-- <Adafruit SSD1306> 2.5.1
| | | |-- <Wire> 1.0.1
| | | |-- <SPI> 1.0
| | |-- <Wire> 1.0.1
| | |-- <SPI> 1.0
| |-- <SPI> 1.0
| |-- <Wire> 1.0.1
|-- <SPI> 1.0
|-- <HTTPClient> 1.2
| |-- <WiFi> 1.0
| |-- <WiFiClientSecure> 1.0
| | |-- <WiFi> 1.0
|-- <WiFi> 1.0
|-- <Adafruit SH1106> 1.0.0
| | | |-- <Wire> 1.0.1
| | | |-- <SPI> 1.0
| | |-- <Wire> 1.0.1
| | |-- <SPI> 1.0
| |-- <SPI> 1.0
| |-- <Wire> 1.0.1
|-- <Wire> 1.0.1
Compiling .pio\build\esp32dev\src\Display.cpp.o
Compiling .pio\build\esp32dev\src\MPU6050.cpp.o
Compiling .pio\build\esp32dev\src\Sleep.cpp.o
Compiling .pio\build\esp32dev\src\main.cpp.o
Compiling .pio\build\esp32dev\src\medicine.cpp.o
Compiling .pio\build\esp32dev\src\menu1.cpp.o
Compiling .pio\build\esp32dev\src\menu2.cpp.o
Compiling .pio\build\esp32dev\src\menu4.cpp.o
Compiling .pio\build\esp32dev\src\menu5.cpp.o
Compiling .pio\build\esp32dev\src\switch.cpp.o
Compiling .pio\build\esp32dev\src\wifi.cpp.o
Generating partitions .pio\build\esp32dev\partitions.bin
Compiling .pio\build\esp32dev\libf75\Wire\Wire.cpp.o
Compiling .pio\build\esp32dev\lib604\SPI\SPI.cpp.o
Archiving .pio\build\esp32dev\lib604\libSPI.a
Compiling .pio\build\esp32dev\libf2f\Adafruit BusIO\Adafruit_BusIO_Register.cpp.o
Archiving .pio\build\esp32dev\libf75\libWire.a
Indexing .pio\build\esp32dev\lib604\libSPI.a
Indexing .pio\build\esp32dev\libf75\libWire.a
Compiling .pio\build\esp32dev\libf2f\Adafruit BusIO\Adafruit_I2CDevice.cpp.o
Compiling .pio\build\esp32dev\libf2f\Adafruit BusIO\Adafruit_SPIDevice.cpp.o
Compiling .pio\build\esp32dev\libe07\Adafruit GFX Library\Adafruit_GFX.cpp.o
Compiling .pio\build\esp32dev\libe07\Adafruit GFX Library\Adafruit_GrayOLED.cpp.o
Archiving .pio\build\esp32dev\libf2f\libAdafruit BusIO.a
Indexing .pio\build\esp32dev\libf2f\libAdafruit BusIO.a
Compiling .pio\build\esp32dev\libe07\Adafruit GFX Library\Adafruit_SPITFT.cpp.o
Compiling .pio\build\esp32dev\libe07\Adafruit GFX Library\glcdfont.c.o
Compiling .pio\build\esp32dev\libffa\Adafruit Unified Sensor\Adafruit_Sensor.cpp.o
Compiling .pio\build\esp32dev\lib28f\Adafruit MPU6050\Adafruit_MPU6050.cpp.o
Compiling .pio\build\esp32dev\libfbc\Adafruit SSD1306\Adafruit_SSD1306.cpp.o
Archiving .pio\build\esp32dev\libe07\libAdafruit GFX Library.a
Indexing .pio\build\esp32dev\libe07\libAdafruit GFX Library.a
Compiling .pio\build\esp32dev\lib7da\WiFi\ETH.cpp.o
Archiving .pio\build\esp32dev\libffa\libAdafruit Unified Sensor.a
Indexing .pio\build\esp32dev\libffa\libAdafruit Unified Sensor.a
Compiling .pio\build\esp32dev\lib7da\WiFi\WiFi.cpp.o
Archiving .pio\build\esp32dev\lib28f\libAdafruit MPU6050.a
Indexing .pio\build\esp32dev\lib28f\libAdafruit MPU6050.a
Compiling .pio\build\esp32dev\lib7da\WiFi\WiFiAP.cpp.o
Archiving .pio\build\esp32dev\libfbc\libAdafruit SSD1306.a
Indexing .pio\build\esp32dev\libfbc\libAdafruit SSD1306.a
Compiling .pio\build\esp32dev\lib7da\WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp32dev\lib7da\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp32dev\lib7da\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\esp32dev\lib7da\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\esp32dev\lib7da\WiFi\WiFiScan.cpp.o
Compiling .pio\build\esp32dev\lib7da\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp32dev\lib7da\WiFi\WiFiUdp.cpp.o
Compiling .pio\build\esp32dev\lib9e0\WiFiClientSecure\WiFiClientSecure.cpp.o
Compiling .pio\build\esp32dev\lib9e0\WiFiClientSecure\ssl_client.cpp.o
Compiling .pio\build\esp32dev\lib136\HTTPClient\HTTPClient.cpp.o
Archiving .pio\build\esp32dev\lib7da\libWiFi.a
Indexing .pio\build\esp32dev\lib7da\libWiFi.a
Compiling .pio\build\esp32dev\libdde\esp32-sh1106-oled-master\Adafruit_SH1106.cpp.o
Archiving .pio\build\esp32dev\libFrameworkArduinoVariant.a
Indexing .pio\build\esp32dev\libFrameworkArduinoVariant.a
Compiling .pio\build\esp32dev\FrameworkArduino\Esp.cpp.o
Archiving .pio\build\esp32dev\lib9e0\libWiFiClientSecure.a
Indexing .pio\build\esp32dev\lib9e0\libWiFiClientSecure.a
Compiling .pio\build\esp32dev\FrameworkArduino\FunctionalInterrupt.cpp.o
Archiving .pio\build\esp32dev\libdde\libesp32-sh1106-oled-master.a
Indexing .pio\build\esp32dev\libdde\libesp32-sh1106-oled-master.a
Compiling .pio\build\esp32dev\FrameworkArduino\HardwareSerial.cpp.o
Archiving .pio\build\esp32dev\lib136\libHTTPClient.a
Indexing .pio\build\esp32dev\lib136\libHTTPClient.a
Compiling .pio\build\esp32dev\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Print.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-log.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-timer.c.o
C:\Users\arjun v\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c: In function 'spiTransferBytesNL':
C:\Users\arjun v\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c:922:39: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
uint8_t * last_out8 = &result[c_longs-1];
C:\Users\arjun v\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c:923:40: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
uint8_t * last_data8 = &last_data;
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\main.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\esp32dev\libFrameworkArduino.a
Indexing .pio\build\esp32dev\libFrameworkArduino.a
Linking .pio\build\esp32dev\firmware.elf
.pio\build\esp32dev\lib7da\libWiFi.a(WiFiClient.cpp.o): In function `WiFiClient::write(unsigned char const*, unsigned int)':
C:\Users\arjun v\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src/WiFiClient.cpp:337:(.text._ZN10WiFiClient5writeEPKhj+0x74): dangerous relocation: windowed longcall crosses 1GB boundary; return may fail: select
.pio\build\esp32dev\lib7da\libWiFi.a(WiFiClient.cpp.o): In function `WiFiClient::connect(IPAddress, unsigned short, int)':
C:\Users\arjun v\.platformio\packages\framework-arduinoespressif32\libraries\WiFi\src/WiFiClient.cpp:337:(.text._ZN10WiFiClient7connectE9IPAddressti+0x248): dangerous relocation: windowed longcall crosses 1GB boundary; return may fail: select
*** [.pio\build\esp32dev\firmware.elf] Error 1
