ESP32 & PIO Unified Debugger
After following driver installation process described in Olimex documentation (see chap. 3.3.3 of https://www.olimex.com/Products/ARM/JTAG/_resources/ARM-USB-OCD_and_OCD_H_manual.pdf), I wanted to start th debug session with F5.
And it gave these errors in the debug console:
Reading symbols from c:/Users/sds-emb/Documents/PlatformIO/Projects/ProjectHuzzah32Arduino/.pioenvs/featheresp32/firmware.elf...
done.
PlatformIO Unified Debugger > xxxxcensored (I can put only 2 links)
PlatformIO: Initializing remote target...
Open On-Chip Debugger 0.10.0-dev (2018-06-04-09:51)
Licensed under GNU GPL v2
For bug reports, read
	xxxcensored
adapter speed: 20000 kHz
esp32 interrupt mask on
force hard breakpoints
Info : tcl server disabled
Info : telnet server disabled
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Error: JTAG scan chain interrogation failed: all zeroes
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: esp32.cpu0: IR capture error; saw 0x00 not 0x01
Warn : Bypassing JTAG setup events due to errors
cpu0: Current bits set: none
cpu1: Current bits set: none
Info : accepting 'gdb' connection from pipe
Error: cpu1: esp32_fetch_all_regs (line 201): DSR (FFFFFFFF) indicates target still busy!
Error: cpu1: esp32_fetch_all_regs (line 201): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu1: esp32_fetch_all_regs (line 201): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: Exception reading acchi!
Info : active_cpu: 0, changed to 1, reson = 0xffffffff
Info : Target halted. PRO_CPU: PC=0x00000000             APP_CPU: PC=0x00000000 (active)
Error: cpu0: xtensa_write_memory (line 711): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: xtensa_write_memory (line 711): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: xtensa_write_memory (line 711): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : esp32: Failed writing 4 bytes at address 0x3FF5F064, data - a1, 3a, d8, 50, a1, 3a, d8, 50
embedded:startup.tcl:21: Error:
in procedure 'halt'
in procedure 'ocd_bouncer'
in procedure 'esp_core_halt'
in procedure 'esp32' called at file "C:/Users/sds-emb/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 44
at file "embedded:startup.tcl", line 21
esp32: target state: halted
Info : Use core1 of target 'esp32'
Error: cpu0: xtensa_read_memory (line 603): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: xtensa_read_memory (line 603): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: xtensa_read_memory (line 603): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : cpu0: Failed reading 7416 bytes at address 0x40090000
Error: no working area available, can't alloc space for stub code!
Error: Failed to load stub (-308)!
Error: Algorithm run faied (-308)!
Info : Auto-detected flash size 0 KB
Error: Failed to probe flash, size 0 KB
Info : esp32: Debug controller was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32: Core was reset (pwrstat=0xFF, after clear 0xFF).
warning: while parsing target memory map (at line 2): Required element <memory> is missing
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1016). Workaround: increase "set remotetimeout" in GDB
Warn : cpu0: Failed reading 2 bytes at address 0x400E4A88
0x00000000 in ?? ()
Not implemented stop reason (assuming exception): undefined
Warn : cpu0: Failed reading 4 bytes at address 0x3FF00030
Error: Failed to read target memory (-4)!
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1054). Workaround: increase "set remotetimeout" in GDB
Warn : cpu0: Failed reading 4 bytes at address 0x3FFC25B0
Error: Could not read FreeRTOS thread count from target
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1004). Workaround: increase "set remotetimeout" in GDB
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1006). Workaround: increase "set remotetimeout" in GDB
Warn : cpu0: Failed reading 2 bytes at address 0x400E4CCB
Hardware assisted breakpoint 1 at 0x400e4ccb: file C:\Users\sds-emb\.platformio\packages\framework-arduinoespressif32\cores\esp32\main.cpp, line 23.
Error: JTAG scan chain interrogation failed: all ones
Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
cpu0: Current bits set: BreakIn BreakOut RunStallIn DebugModeOut
cpu1: Current bits set: BreakIn BreakOut RunStallIn DebugModeOut
Warn : cpu0: Failed reading 76 bytes at address 0x50000000
Error: esp32_soc_reset 551 err=-4
in procedure 'program_esp32'
in procedure 'reset' called at file "C:/Users/sds-emb/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 123
embedded:startup.tcl:454: Error: ** Unable to reset target **
in procedure 'program_error' called at file "C:/Users/sds-emb/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 124
at file "embedded:startup.tcl", line 454
Info : TAP esp32.cpu0 does not have IDCODE
Info : TAP esp32.cpu1 does not have IDCODE
Info : TAP auto0.tap does not have IDCODE
Info : TAP auto1.tap does not have IDCODE
Info : TAP auto2.tap does not have IDCODE
Info : TAP auto3.tap does not have IDCODE
Info : TAP auto4.tap does not have IDCODE
Info : TAP auto5.tap does not have IDCODE
Info : TAP auto6.tap does not have IDCODE
Info : TAP auto7.tap does not have IDCODE
Info : TAP auto8.tap does not have IDCODE
Info : TAP auto9.tap does not have IDCODE
Info : TAP auto10.tap does not have IDCODE
Info : TAP auto11.tap does not have IDCODE
Info : TAP auto12.tap does not have IDCODE
Info : TAP auto13.tap does not have IDCODE
Info : TAP auto14.tap does not have IDCODE
Info : TAP auto15.tap does not have IDCODE
Info : TAP auto16.tap does not have IDCODE
Info : TAP auto17.tap does not have IDCODE
Info : TAP auto18.tap does not have IDCODE
Warn : Unexpected idcode after end of chain: 21 0x00000000
Warn : Unexpected idcode after end of chain: 53 0x00000000
Warn : Unexpected idcode after end of chain: 85 0x00000000
Warn : Unexpected idcode after end of chain: 117 0x00000000
Warn : Unexpected idcode after end of chain: 149 0xfffffff8
Error: double-check your JTAG setup (interface, speed, ...)
Info : JTAG tap: esp32.cpu0 tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Warn : JTAG tap: esp32.cpu0       UNEXPECTED: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Error: JTAG tap: esp32.cpu0  expected 1 of 1: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : JTAG tap: esp32.cpu1 tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Warn : JTAG tap: esp32.cpu1       UNEXPECTED: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Error: JTAG tap: esp32.cpu1  expected 1 of 1: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : JTAG tap: auto0.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto1.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto2.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto3.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto4.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto5.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto6.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto7.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto8.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto9.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto10.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto11.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto12.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto13.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto14.tap tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Info : JTAG tap: auto15.tap tap/device found: 0x7fffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0x7)
Warn : Unexpected idcode after end of chain: 580 0x00000002
Warn : Unexpected idcode after end of chain: 612 0x00000000
Warn : Unexpected idcode after end of chain: 644 0x00000000
PlatformIO: Initialization completed
PlatformIO: Resume the execution to `debug_init_break = thb app_main`
Error: cpu0: esp32_fetch_all_regs (line 171): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_fetch_all_regs (line 171): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_fetch_all_regs (line 171): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (2020). Workaround: increase "set remotetimeout" in GDB
Error: cpu0: esp32_fetch_all_regs (line 201): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_fetch_all_regs (line 201): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_fetch_all_regs (line 201): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1011). Workaround: increase "set remotetimeout" in GDB
Error: Exception reading pc!
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1015). Workaround: increase "set remotetimeout" in GDB
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (1001). Workaround: increase "set remotetimeout" in GDB
Error: cpu0: esp32_write_dirty_registers (line 326): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_write_dirty_registers (line 326): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_write_dirty_registers (line 326): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: cpu1: esp32_write_dirty_registers (line 326): DSR (FFFFFFFF) indicates target still busy!
Error: cpu1: esp32_write_dirty_registers (line 326): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu1: esp32_write_dirty_registers (line 326): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: cpu0: xtensa_resume (line 446): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: xtensa_resume (line 446): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: xtensa_resume (line 446): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: cpu1: xtensa_resume (line 446): DSR (FFFFFFFF) indicates target still busy!
Error: cpu1: xtensa_resume (line 446): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu1: xtensa_resume (line 446): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Info : active_cpu: 1, changed to 0, reson = 0xffffffff
Program received signal
SIGINT, Interrupt.
0x00000000 in ?? ()
while OLIMEX tool Led is blinking
After that I tried to put some breakpoints, an push starts, nothing happens, the blinky arduino code doesn’t even make the led blink on the board.
I had the following error messages on the debug console:
Warn : xtensa_read_memory: esp32: target not halted
Warn : WARNING! The target is already running. All changes GDB did to registers will be discarded! Waiting for target to halt.
Info : Halt timed out, wake up GDB.
Warn : target esp32 is not halted
Error: FreeRTOS_update_threads not TARGET_HALTED!
Remote target] #1 stopped.
0x00000000 in ?? ()
And the Olimex tool led is still blinking
My hardware set up is Windows 8.1, VSCode (last version), pio core version 3.6.1a1
And the hardware wiring is the one described here : Debugging ESP32 · Pro/open62541-arduino Wiki · GitHub
*** UPDATE1 ***
After two or tree tries my Adafruit HUZZAH32 has stopped to work, I can not even upload the simple blinky example to normal process: The PC does not even detect the board !!!
More details: Since there is already Blinky programm in it, when I plug it in my PC (or a powered USB hub) it blinks 1 or 2 secs, then it stops and the board warms up.
*** UPDATE2 *** Update after a last retry, the CP2104 component burnt ! I can’t programm the Adafruit board trough USB anymore !
I think however that the target is still programmable via JTAG controller (if it is correctly wired). Correct me if I’m wrong.
Yes. It can be programmed by Jtag.
-Make sure the Jtag is connected correctly to the target board.
-Make sure you set on platformio.ini “debug_tool = olimex-arm-usb-ocd-h” or “debug_tool = ftdi”
I never tested platformio with olimex jtag… but it should work like any other ftdi based jtag.
Still, i recommend using the zadig solution for the driver. Is tested and working.
Zadig is recommended inside the documentation protocol of the Olimex tool so I used Zadig.
I didn’t succed into programming it via the JTAG, I don’t know if the wiring is correct, I didn’t find any documentation which explain how to connect it exept that link I gave above. I’ve noticed him about what happened and he answered:
Thanks for the info, but as always with microcontroller programming: You really have to know what you are doing. There can be many reasons why your board broke. The only think I know for sure is that the procedure worked for me. Note that I did not use platform.io at all…
Have you seen this Olimex ARM-USB-OCD-H — PlatformIO latest documentation ?
Yes, but there is no information in Adafruit website of where are the pins of JTAG debugging on their Adafruit Huzzah32 board
So I based myself on this schema below from this tutorial (next link): Debugging ESP32 · Pro/open62541-arduino Wiki · GitHub
How to configure PlatformIO in order to upload the firmware via the Olimex JTAG debugger ?
Use 'Pio Debug" and platformio will compile the project, upload to target using Jtag, then will start the debug session.
Please take a look at hint on your screenshot. AVAILABLE: ...., CURRENT: ..., upload_protocol = ....
http://docs.platformio.org/en/latest/projectconf/section_env_upload.html#upload-protocol
Thanks, I removed the connection to the 3V which makes my dev board shutdown, I added the configuration of the upload_protcol.
And I got this (and the upload failed):
Processing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)
PLATFORM: Espressif 32 > Adafruit ESP32 Feather
SYSTEM: ESP32 240MHz 320KB RAM (4MB Flash)
DEBUG: CURRENT(olimex-arm-usb-ocd-h) EXTERNAL(esp-prog, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny)
Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF MODES: FINDER(chain) COMPATIBILITY(soft)
Collected 24 compatible libraries
No dependencies
Retrieving maximum program size .pioenvs\featheresp32\firmware.elf
Checking size .pioenvs\featheresp32\firmware.elf
DATA:    [          ]   4.2% (used 13884 bytes from 327680 bytes)
PROGRAM: [=         ]  13.6% (used 178024 bytes from 1310720 bytes)
AVAILABLE: esp-prog, esptool, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny
CURRENT: upload_protocol = olimex-arm-usb-ocd-h
Uploading .pioenvs\featheresp32\firmware.bin
Error: timed out while waiting for target halted / 1 - 2
Error: Exception reading interrupt!
Info : Target halted. PRO_CPU: PC=0x00000000 (active)    APP_CPU: PC=0x00000000
Error: Exception reading ccompare0!
Warn : esp32: Failed writing 4 bytes at address 0x3FF5F048, data - 00, 00, 00, 00, 00, 00, 00, 00
in procedure 'reset' called at file "C:\Users\c\.platformio\packages\tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 123
in procedure 'ocd_process_reset'
in procedure 'ocd_process_reset_inner' called at file "embedded:startup.tcl", line 248
in procedure 'esp32' called at file "embedded:startup.tcl", line 312
in procedure 'esp32' called at file "C:\Users\c\.platformio\packages\tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 45
Warn : esp32: Failed writing 4 bytes at address 0x3FF0002C, data - 00, 00, 00, 00, e8, dd, 28, 00
Error: xtensa_write_uint32_list: error writing to 3ff0002c
Warn : esp32_soc_reset xtensa_write_uint32_list (reg_value_pairs_post) err=-4
Error: esp32_soc_reset: Couldn't halt target before SoC reset! (xtensa_assert_reset returned -4)
in procedure 'program_error' called at file "C:\Users\c\.platformio\packages\tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 124
*** [upload] Error 1
============================================================================================== [ERROR] Took 6.84 seconds ==============================================================================================
Le processus du terminal s'est achevé avec le code de sortie 1
Le terminal sera réutilisé par les tâches, appuyez sur une touche pour le fermer.
There is something wrong with the connection between Jtag and the ESP32 board…
Try to swap TDI/TDO pins…
@botofancalin I did it and these are the results:
    > Executing task: C:\Users\c\.platformio\penv\Scripts\platformio.exe run --target upload <
    No dependencies
    Warn : esp32: Failed writing 4 bytes at address 0x3FF60064, data - a1, 3a, d8, 50, a1, 3a, d8, 50
    in procedure 'esp32' called at file "C:\Users\c\.platformio\packages\tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 47
    Warn : esp32: Failed writing 76 bytes at address 0x50000000, data - 00, 00, 00, 00, 00, 00, 00, 00
    Error: esp32_soc_reset 632 err=-4
    ============================================================================================== [ERROR] Took 7.38 seconds ==============================================================================================
Still, there are connection problems…
Please check the connection. It should be like this:
TDI -> GPIO12
TCK -> GPIO13
TMS ->GPIO14
TDO -> GPIO15
TRST -> EN (Reset)
GND -> GND
I don’t have the Olimex Jtag.
Maybe the Olimex use the other channel of FT2232 as Jtag. That can be investigated on the Jtag schematic.
I use various FT232H and FT2232D chip’s as jtag’s, even from old salvaged pcb’s and they all work once they are connected properly.
As you can see in the schema I posted above all of this is respected except that VCC which was connected to the 3V board.
As I said just 2 comments before, I removed the VCC connection (which causes mes problems) then I did the test with the result above (see 2 comments before).
I did another test by connecting TRST to RST pin instead of EN. This, because EN is not a reset pin
However, it gave me always the same answer : “unable to reset target”
Ok I found something else. His tutorial wiring instruction (here: Debugging ESP32 · Pro/open62541-arduino Wiki · GitHub) are all reversed, this is why my USB chip burnt.
(more details: The wiring in the tutorial is all reversed · Issue #5 · Pro/open62541-arduino · GitHub)
I’ve remade the wiring in the good order. But still have the same error: embedded:startup.tcl:454: Error: ** Unable to reset target ** like he doesn’t see any board
No dependencies
in procedure 'init' called at file "C:\Users\c\.platformio\packages\tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 118
in procedure 'esp_smp_break_config'
in procedure 'esp32' called at file "C:\Users\c\.platformio\packages\tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 54
in procedure 'esp32' called at file "C:\Users\c\.platformio\packages\tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 44
============================================================================================== [ERROR] Took 3.79 seconds ==============================================================================================
I suspect this time that the Olimex has been damaged by the previous manipulation.
Update :
The responsible of this schema has just updated his documentation with a note and removing the misleading poka yoke on the schema
Do you think that my probe could have been damaged now ?
I don’t know exactly what other chip is on the Olimex jtag beside FT2232.
The FT2232 is not that easy to damage…
Most likely the ESP32 was damaged if VCC from Olimex was higher than 3.3V or target VCC was shorted to GND.
I don’t know but the blinky programm of the ESP-32 is still working
I use Olimex ARM-USB-TINY-H and it works like a charm. Could you make a photo how did you connect it with your board?
