I recently tried to update the platform version for my project from 53.XX.XX to latest 55.03.37. This caused a looping boot crash of Illegal Instruction panics, i also tried 55.03.35, same issue, it was only 54.03.21-2 that i could get working.
Its an Arduino framework project.
The project ini currently:
; Creo_Presenter_Remote - PlatformIO configuration (ESP32-P4)
; Mainline build targets:
; - olimex-esp32-p4 (default)
; - olimex-esp32-p4_debug (debug)
; Legacy / esp32dev environments live in: platformio_legacy.ini
[platformio]
default_envs = olimex-esp32-p4
src_dir = src
; Common settings applied to all envs in this file
[env]
; NOTE (ESP32-P4): 55.03.36+ / 55.03.37 can boot-loop with pre-setup
; Illegal Instruction panics on some P4 devices. Keep the default on 55.03.35
; and provide explicit fallback envs below for fast A/B checks.
platform = https://github.com/pioarduino/platform-espressif32/releases/download/54.03.21-2/platform-espressif32.zip
extra_scripts =
pre:buildscript_versioning.py
pre:toolchain_path_fix.py
; If you want to pin Arduino core later, you can re-enable this section
;platform_packages =
; Shared include paths + diagnostic flags
-DCONFIG_ARDUHAL_POST_SETUP_HEAP_DUMP=0
-I"${PROJECT_DIR}/include"
-I"${PROJECT_DIR}/src/app/include"
-I"${PROJECT_DIR}/src/hal/bsp/include"
-Wl,-Map,${PROGNAME}.map
-DCORE_DEBUG_LEVEL=ARDUHAL_LOG_LEVEL_ERROR
-DLOG_LOCAL_LEVEL=0
; Log toggles (compile-time). Default to quiet logs for production.
; Enable as needed by adding =1.
-DDISPLAY_LOG_CAMSTATUS=0
-DPWRLIGHT_LOG_OFFLINE_GUARD=0
-DNETWORK_RECOVERY_LOG_STATE=0
; Recovery / reachability probe tuning (compile-time).
; Note: “ping” is a strictly time-bounded reachability probe used by central
; recovery (and a couple of module-local health checks).
-DNETWORK_RECOVERY_PING_TIMEOUT_MS=200
-DCAMS_PING_TIMEOUT_MS=250
-DPWRLIGHT_CLIENT_HEALTH_TIMEOUT_MS=200
-DBOARD_HAS_PSRAM
-DCUSTOM_DISPLAY_LIB
-DCONFIG_FREERTOS_USE_TRACE_FACILITY=1
-DCONFIG_FREERTOS_GENERATE_RUN_TIME_STATS=1
-DCONFIG_FREERTOS_RUN_TIME_STATS_USING_ESP_TIMER=1
-DCONFIG_FREERTOS_USE_STATS_FORMATTING_FUNCTIONS=1
-DCONFIG_ASYNC_TCP_STACK_SIZE=32768
-Wno-deprecated-declarations
; CAN / TWAI (classic CAN) config (compile-time)
; Default is disabled so builds work without wiring.
; Set CREO_CAN_ENABLE=1 and pick valid GPIOs for your transceiver module.
-DCREO_CAN_ENABLE=1
; -DCREO_CAN_TX_PIN=22
; -DCREO_CAN_RX_PIN=21
-DCREO_CAN_BITRATE=500000
-DCREO_PMU16_SIM=0
; Optional CAN bus sniffer + BlinkMarine self-test helpers (debug only)
; -DCREO_CAN_SNIFF=1
-DCREO_BM_TEST=1
-DCREO_BM_NODEID=0x15
; -DCREO_CAN_SELFTEST=1 ; internal self-reception test (prints PASS/FAIL once at boot)
; -DCREO_CAN_TWAI_MODE=2 ; 2=listen-only (passive sniff), 1=no-ack, 0=normal
; -DCREO_CAN_DIAG=1 ; prints TWAI error counters/state once per second
; -DCREO_FD_VERBOSE_DIAG=1 ; FD tracking diag (heavy, can cause boot WDT on P4 - debug only)
; If your keypad powers up in J1939 mode, try forcing a switch to CANopen:
; -DCREO_BM_TRY_J1939_TO_CANOPEN=1
; -DCREO_BM_J1939_ADDR=0x21
; Libraries shared across both release + debug
ESP32Async/AsyncTCP@3.4.2
ESP32Async/ESPAsyncWebServer@3.7.7
bblanchon/ArduinoJson@^7.4.1
Networking
adafruit/Adafruit GFX Library@^1.12.1
adafruit/Adafruit SSD1351 Library@^1.0.6
lib_ignore =
AsyncTCP_RP2040W
ESPAsyncTCP
; Filesystem and partitions
board_build.filesystem = spiffs
; Mainline environment (ESP32-P4)
[env:olimex-esp32-p4]
board = olimex-esp32-p4
board_build.partitions = default_16MB.csv
${env.build_flags}
-DCREO_BOARD_ESP32_P4
-DARDUINO_USB_MODE=1
-DARDUINO_USB_CDC_ON_BOOT=1
-DSERVICE_MANAGER_ENABLED
; Debug environment (ESP32-P4) - extends mainline env
[env:olimex-esp32-p4_debug]
extends = env:olimex-esp32-p4
build_type = debug
${env:olimex-esp32-p4.build_flags}
-DDEBUG_LONG_CRIT
-DWSDEBUG_ENABLED=1
; -DDEV_FORCE_DELETE_ON_STOP_TIMEOUT=1 ; removed: unsafe in production (avoid vTaskDelete() fallback)
I had to delete some of the ini as apparently the post cannot contain more the 2 links….
Has anyone experienced similar issues on the ESP32-P4 using Arduino Framework?
Many thanks
