I have searched in vein for information to get an ESP32 running OTA under PlatformIO.
Is this the correct forum to ask for such help?
What search terms did you enter? It’s right there in the documentation.
Thank you for your email Maximillian.
ESP32 PLATFORMIO OTA.
I did see this in my search and do not comprehend its meaning. I recently learned about the concept of OTA and then looked for a start to finish guide.
As a newbie using PlatformIO, does anyone know of a step by step guide of what I need to do to update my ESP32 so they might accept a code refresh periodically?
Refer to resources like ESP32 OTA, I'm confused - #2 by ivankravets.
Really it’s just as easy as
- adding the ArduinoOTA init code in
setup()and the handle code inloop()like in the example - checking out what IP address your ESP32 has (e.g. in the router or serial monitor once), or using mDNS names
- adapting the
platformio.inito use the OTA upload code as shown in the docs above like
upload_protocol = espota
upload_port = IP_ADDRESS_HERE or mDNS_NAME.local
- using the normal upload button of the IDE.
I suppose one man’s just as easy is another’s man’s frustration
Something imust be wrong with my environment.
My platformio.ini file is as follows:
monitor_speed=115200
;upload_port = COM[4]
;upload_port = COM[6]
upload_port = 10.0.4.4
; for "chipMAC": "FC:F5:C4:31:71:04",
;upload_protocol = esp-prog
upload_flags = --8266
;upload_port = 10.0.4.4
;debug_tool = esp-prog
;debug_init_break = tbreak setup
ArduinoOTA
When I compile I get a slew of errors emanating from ArdunioOTA class as such:
The terminal process "C:\Users\Tom\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
> Executing task: C:\Users\Tom\.platformio\penv\Scripts\platformio.exe run <
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 1.12.4 #72b15f6 > Espressif ESP32 Dev Module
- tool-openocd-esp32 1.1000.20190708 (10.0)
Found 34 compatible libraries
|-- <ArduinoOTA> 1.0.5
| |-- <Update> 1.0
| |-- <SD(esp32)> 1.0.5
| | |-- <FS> 1.0
| | |-- <SPI> 1.0
| |-- <WiFi> 1.0
|-- <ESPmDNS> 1.0
| |-- <WiFi> 1.0
|-- <WiFi> 1.0
Compiling .pio\build\esp32dev\src\main.cpp.o
Generating partitions .pio\build\esp32dev\partitions.bin
Compiling .pio\build\esp32dev\libb98\Update\Updater.cpp.o
Compiling .pio\build\esp32dev\lib6d4\FS\FS.cpp.o
Compiling .pio\build\esp32dev\lib6d4\FS\vfs_api.cpp.o
Compiling .pio\build\esp32dev\lib0cb\SPI\SPI.cpp.o
Compiling .pio\build\esp32dev\lib4d4\SD\SD.cpp.o
Compiling .pio\build\esp32dev\lib4d4\SD\sd_diskio.cpp.o
Compiling .pio\build\esp32dev\lib4d4\SD\sd_diskio_crc.c.o
Compiling .pio\build\esp32dev\lib890\WiFi\ETH.cpp.o
Compiling .pio\build\esp32dev\lib890\WiFi\WiFi.cpp.o
Compiling .pio\build\esp32dev\lib890\WiFi\WiFiAP.cpp.o
Archiving .pio\build\esp32dev\lib0cb\libSPI.a
Compiling .pio\build\esp32dev\lib890\WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp32dev\lib890\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp32dev\lib890\WiFi\WiFiMulti.cpp.o
src\main.cpp: In function 'void setup()':
src\main.cpp:23:14: error: 'class ArduinoOTAMdnsClass<WiFiServer, WiFiClient, WiFiUDP>' has no member named 'onStart'
ArduinoOTA.onStart([]() {
src\main.cpp: In lambda function:
src\main.cpp:25:20: error: 'class ArduinoOTAMdnsClass<WiFiServer, WiFiClient, WiFiUDP>' has no member named 'getCommand'
if (ArduinoOTA.getCommand() == U_FLASH)
src\main.cpp:25:36: error: 'U_FLASH' was not declared in this scope
src\main.cpp:32:14: error: 'class ArduinoOTAMdnsClass<WiFiServer, WiFiClient, WiFiUDP>' has no member named 'onEnd'
ArduinoOTA.onEnd([]() { Serial.println("\nEnd"); });
src\main.cpp:33:14: error: 'class ArduinoOTAMdnsClass<WiFiServer, WiFiClient, WiFiUDP>' has no member named 'onProgress'
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
src\main.cpp:36:25: error: 'ota_error_t' has not been declared
ArduinoOTA.onError([](ota_error_t error) {
src\main.cpp:38:18: error: 'OTA_AUTH_ERROR' was not declared in this scope
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
src\main.cpp:39:23: error: 'OTA_BEGIN_ERROR' was not declared in this scope
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
src\main.cpp:40:23: error: 'OTA_CONNECT_ERROR' was not declared in this scope
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
src\main.cpp:41:23: error: 'OTA_RECEIVE_ERROR' was not declared in this scope
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
src\main.cpp:42:23: error: 'OTA_END_ERROR' was not declared in this scope
else if (error == OTA_END_ERROR) Serial.println("End Failed");
src\main.cpp:43:4: error: invalid user-defined conversion from 'setup()::<lambda(int)>' to 'void (*)(int, const char*)' [-fpermissive]
src\main.cpp:36:42: note: candidate is: setup()::<lambda(int)>::operator void (*)(int)() const <near match>
src\main.cpp:36:42: note: no known conversion from 'void (*)(int)' to 'void (*)(int, const char*)'
In file included from .pio\libdeps\esp32dev\ArduinoOTA\src/ArduinoOTA.h:22:0,
from src\main.cpp:4:
.pio\libdeps\esp32dev\ArduinoOTA\src/WiFiOTA.h:49:8: note: initializing argument 1 of 'void WiFiOTAClass::onError(void (*)(int, const char*))'
void onError(void (*fn)(int code, const char* msg)) {
src\main.cpp:44:20: error: no matching function for call to 'ArduinoOTAMdnsClass<WiFiServer, WiFiClient, WiFiUDP>::begin()'
ArduinoOTA.begin();
In file included from src\main.cpp:4:0:
.pio\libdeps\esp32dev\ArduinoOTA\src/ArduinoOTA.h:87:8: note: candidate: void ArduinoOTAMdnsClass<NetServer, NetClient, NetUDP>::begin(IPAddress, const char*, const char*, OTAStorage&) [with NetServer = WiFiServer; NetClient = WiFiClient; NetUDP = WiFiUDP]
void begin(IPAddress localIP, const char* name, const char* password, OTAStorage& storage) {
.pio\libdeps\esp32dev\ArduinoOTA\src/ArduinoOTA.h:87:8: note: candidate expects 4 arguments, 0 provided
src\main.cpp:49:11: error: 'LED_BUILTIN' was not declared in this scope
pinMode(LED_BUILTIN, OUTPUT);
src\main.cpp: In function 'void loop()':
src\main.cpp:56:16: error: 'LED_BUILTIN' was not declared in this scope
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
*** [.pio\build\esp32dev\src\main.cpp.o] Error 1
========================================================================== [FAILED] Took 8.93 seconds ==========================================================================The terminal process "C:\Users\Tom\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
That flag isn’t accepted by the espota program, did you mean --port=8266? This is already default so no need to specify.
No, ArduinoOTA from the library registry is a different library from the ArduinoOTA library which is contained in the Arduino-ESP32 core (arduino-esp32/libraries/ArduinoOTA at master · espressif/arduino-esp32 · GitHub). For libraries within the core, do not use lib_deps, these are found automatically.
Make sure when you do a “Verbose Build” that you get a library dependency view which only references core internal libraries as in
Then it will compile.
Thank you.
This did the trick. I’m now compiling
Your link here about OTA documentation is great. I am working on OTA for espidf and find it hard to get started with Simple OTA as outlined in the documentation. The document sounds like simply put the code in src folder but looking at the code I suppose it needs some works. Could you please provide any details on this part?
