I am trying to get familiar with OTAs.
Therefore I’ve setup a small project with my ESP32 (DoIT DevKit).
My platformio.ini looks like this:
[env:serial]
board = esp32doit-devkit-v1
framework = arduino, espidf
'-D WIFI_SSID="MY_SSID"'
'-D WIFI_PW="MY_PW"'
[env:ota]
extends = env:serial
upload_protocol = espota
upload_port = 10.0.237.54
I’ve successfully connected the ESP32 to my Wifi.
The main.cpp looks like this
#include "freertos/task.h"
#include "driver/gpio.h"
#include "InterruptButton.h"
#include "WiFi.h"
#include "ArduinoOTA.h"
#include "nvs_flash.h"
#include "esp_err.h"
const char *ssid = WIFI_SSID;
const char *password = WIFI_PW;
InterruptButton button(GPIO_NUM_0, 0);
void configure_led()
gpio_reset_pin(GPIO_NUM_2);
gpio_set_direction(GPIO_NUM_2, GPIO_MODE_INPUT_OUTPUT);
void configure_wifi()
WiFi.mode(WIFI_MODE_STA);
WiFi.begin(ssid, password);
while (WiFi.waitForConnectResult() != WL_CONNECTED)
Serial.println("Connection Failed! Rebooting...");
delay(5000);
ESP.restart();
printf("Connected to WiFi: %s\n", WiFi.localIP().toString().c_str());
void callback()
uint8_t state = gpio_get_level(GPIO_NUM_2);
printf("Toggeling LED: %i\n", state);
gpio_set_level(GPIO_NUM_2, !state);
// printf("Async blink");
// gpio_set_level(GPIO_NUM_2, 1);
// vTaskDelay(1000 / portTICK_PERIOD_MS);
// gpio_set_level(GPIO_NUM_2, 0);
extern "C" void app_main()
nvs_flash_init();
configure_wifi();
configure_led();
button.bind(Event_KeyDown, &callback);
ArduinoOTA.begin();
while (1)
vTaskDelay(5 / portTICK_PERIOD_MS);
ArduinoOTA.handle();
When flashing via USB, the project is working. It outputs the IP after initialization and pressing the button, turns the LED on and off.
When flashing via espota, I see the following message:
17:26:51 [DEBUG]: Options: {'esp_ip': '10.0.237.54', 'host_ip': '0.0.0.0', 'esp_port': 3232, 'host_port': 17226, 'auth': '', 'image': '.pio/build/ota/firmware.bin', 'spiffs': False, 'debug': True, 'progress': True, 'timeout': 10}
17:26:51 [INFO]: Starting on 0.0.0.0:17226
17:26:51 [INFO]: Upload size: 751120
Sending invitation to 10.0.237.54
17:26:52 [INFO]: Waiting for device...
17:27:02 [ERROR]: No response from device
*** [upload] Error 1
In addition, there is a very last message printed on the serial monitor:
[ 29961][E][ArduinoOTA.cpp:252] _runUpdate(): Begin ERROR: Partition Could Not be Found
I am confused by the message. Would I have to create a separate partition on something like this?
I haven’t changed anything through the menuconfig.
Can anyone imagine, what’s wrong here?
Thanks in advance!
