Okay, I now got this:
Executing task: C:\Users\Niels\.platformio\penv\Scripts\platformio.exe run --verbose --target upload --environment nodemcu-32s <
Processing nodemcu-32s (platform: https://github.com/platformio/platform-espressif32.git; board: nodemcu-32s; board_debug.adapter_speed: 500; board_upload.flash_size: 4MB; board_upload.maximum_size: 4194304; framework: espidf; monitor_speed: 115200; debug_tool: olimex-arm-usb-ocd-h; upload_protocol: olimex-arm-usb-ocd-h; board_build.partitions: ESP32_OTA_4M.csv)
-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/nodemcu-32s.html
PLATFORM: Espressif 32 (2.0.0+sha.07919d0) (git+https://github.com/platformio/platform-espressif32.git) > NodeMCU-32S
DEBUG: Current (olimex-arm-usb-ocd-h) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-espidf 3.40100.200827 (4.1.0)
- tool-cmake 3.16.4
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- tool-openocd-esp32 2.1000.20200709 (10.0)
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32 2.80200.200827 (8.2.0)
Framework incompatible library C:\Users\Niels\.platformio\lib\DallasTemperature_ID54
Framework incompatible library C:\Users\Niels\.platformio\lib\IniFile_ID1606
Framework incompatible library C:\Users\Niels\.platformio\lib\MPL115A1_ID2547
Framework incompatible library C:\Users\Niels\.platformio\lib\NTPClient
Framework incompatible library C:\Users\Niels\.platformio\lib\OneWire_ID1
Framework incompatible library C:\Users\Niels\.platformio\lib\PID_ID2
Framework incompatible library C:\Users\Niels\.platformio\lib\SdFat_ID322
Framework incompatible library C:\Users\Niels\.platformio\lib\Sqlite3Esp32_ID6173
Framework incompatible library C:\Users\Niels\.platformio\lib\TFT_eSPI
More details about "Library Compatibility Mode": https://docs.platformio.org/page/librarymanager/ldf.html#ldf-compat-mode
Found 2 compatible libraries
|-- <TempIF> (C:\Users\Niels\Documents\PlatformIO\Projects\nanoBrewer\lib\TempIF)
|-- <mongoose_espidf> 0.1.0 (C:\Users\Niels\Documents\PlatformIO\Projects\nanoBrewer\lib\Mongoose)
<lambda>(["checkprogsize"], [".pio\build\nodemcu-32s\firmware.elf"])
MethodWrapper(["checkprogsize"], [".pio\build\nodemcu-32s\firmware.elf"])
RAM: [= ] 11.6% (used 38104 bytes from 327680 bytes)
Flash: [===== ] 53.6% (used 843218 bytes from 1572864 bytes)
.pio\build\nodemcu-32s\firmware.elf :
section size addr
.rtc.text 0 1074528256
.rtc.dummy 0 1073217536
.rtc.force_fast 0 1073217536
.rtc_noinit 0 1342177280
.rtc.force_slow 0 1342177280
Open On-Chip Debugger v0.10.0-esp32-20200709 (2020-07-09-08:54)
.iram0.vectors 1027 1074266112
Licensed under GNU GPL v2
.iram0.text 94940 1074267140
For bug reports, read
.dram0.data 14840 1073414144
debug_level: 2
.noinit 0 1073428984
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
Info : Configured 2 cores
.dram0.bss 23264 1073428984
adapter speed: 20000 kHz
.flash.rodata 132072 1061158944
.flash.text 600339 1074593824
.iram0.text_end 0 1074362080
.dram0.heap_start 0 1073452248
.xtensa.info 56 0
.comment 217 0
.xt.prop._ZN3nvs9NVSHandle8set_itemIaEEiPKcT_ 36 0
.xt.prop._ZN3nvs9NVSHandle8set_itemIhEEiPKcT_ 36 0
.xt.prop._ZN3nvs9NVSHandle8set_itemItEEiPKcT_ 36 0
.xt.prop._ZN3nvs9NVSHandle8set_itemIjEEiPKcT_ 36 0
.xt.prop._ZN3nvs9NVSHandle8get_itemIaEEiPKcRT_ 36 0
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000.xt.prop._ZN3nvs9NVSHandle8get_itemIhEEiPKcRT_ 36 0
k
Hz.xt.prop._ZN3nvs9NVSHandle8get_itemItEEiPKcRT_ 36 0
.xt.prop._ZN3nvs9NVSHandle8get_itemIjEEiPKcRT_ 36 0
.xt.lit._ZN3nvs19NVSPartitionManagerD5Ev 0 0
Info : Listening on port 3333 fo
r gdb c.xt.prop._ZN3nvs19NVSPartitionManagerD5Ev 0 0
onn
ect.xt.prop._ZN3nvs19NVSPartitionManagerD2Ev 36 0
io
ns.xt.prop._ZN3nvs19NVSPartitionManagerD0Ev 36 0
.xt.prop._ZTVN3nvs19NVSPartitionManagerE 12 0
Info : cpu0: Target halted, PC=0x40007BA1, debug_reason=000.xt.prop._ZTVN3nvs15NVSHandleSimpleE 12 0
00000
Info : cpu0: Debug controller 0 was reset.
.xt.prop._ZTISt9exception 12 0
Info : cpu0: Core 0 was reset.
.xt.prop._ZTISt9bad_alloc 12 0
Info : cpu0: Target halted, PC=0x50000
0CF, debug_reason=00.xt.prop._ZTVN10__cxxabiv120__si_class_type_infoE 12 0
000000
Info : esp32: Core 0 was reset.
.xt.prop._ZTVSt9bad_alloc 12 0
Info : esp32: Debug controller 1 was reset.
.xt.prop._ZTVN10__cxxabiv117__class_type_infoE 12 0
Info : esp32: Core 1 was reset.
.debug_frame 109080 0
Info : Target halted. CPU0: PC=0x40000400 (active
).debug_info 3963645 0
Info : Target halted. CPU1: PC=0x4000
0400
.debug_abbrev 317612 0
** Programming Started **
.debug_aranges 42112 0
.debug_ranges 47360 0
.debug_line 1941276 0
.debug_str 310417 0
.debug_loc 854930 0
Total 8453631
<lambda>(["upload"], [".pio\build\nodemcu-32s\firmware.bin"])
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = olimex-arm-usb-ocd-h
openocd -d2 -s C:/Users/Niels/.platformio/packages/tool-openocd-esp32/share/openocd/scripts -f interface/ftdi/olimex-arm-usb-ocd-h.cfg -f board/esp-wroom-32.cfg -c "adapter_khz 20000" -c "program_esp {{.pio\build\nodemcu-32s\firmware.bin}} 0x10000 verify" -c "program_esp {{C:\Users\Niels\Documents\PlatformIO\Projects\nanoBrewer\.pio\build\nodemcu-32s/bootloader.bin}} 0x1000 verify" -c "program_esp {{C:\Users\Niels\Documents\PlatformIO\Projects\nanoBrewer\.pio\build\nodemcu-32s/partitions.bin}} 0x8000 verify" -c "reset run; shutdown"
Error: timed out while waiting for target halted / 4 - 2
Info : cpu0: Target halted, PC=0x40090155, debug_reason=00000000
Error: xtensa_wait_algorithm: not halted 0, pc 0x40090155, ps 0x60025
Error: Failed to wait algorithm (-302)!
Error: Algorithm run failed (-302)!
Error: Failed to run flasher stub (-302)!
Warn : Failed to get flash mappings (-302)!
Error: Target is already running an algorithm
Error: Failed to start algorithm (-4)!
Error: Algorithm run failed (-4)!
Error: Failed to run flasher stub (-4)!
Error: Failed to probe flash, size 0 KB
Error: auto_probe failed
embedded:startup.tcl:449: Error: ** Programming Failed **
in procedure 'program_esp'
in procedure 'program_error' called at file "C:/Users/Niels/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp_common.cfg", line 106
at file "embedded:startup.tcl", line 449
*** [upload] Error 1
============================================================================================= [FAILED] Took 65.14 seconds =============================================================================================The terminal process "C:\Users\Niels\.platformio\penv\Scripts\platformio.exe 'run', '--verbose', '--target', 'upload', '--environment', 'nodemcu-32s'" terminated with exit code: 1.
