I’m fixing an old project on platformio, a Nes emulator based on nofrendo. However, I came across an error that is causing my esp32 Dev kit 4 to reset.
NOTE: I tried resetting ESP_TASK_MAIN_STACK in my main.c for testing #define ESP_TASK_MAIN_STACK (CONFIG_ESP_MAIN_TASK_STACK_SIZE + 2048)
I’m having the following:
Guru Meditation Error: Core 0 panic'ed (StoreProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x4000c46c PS : 0x00060630 A0 : 0x800d5af0 A1 : 0x3ffbd270
A2 : 0x00000028 A3 : 0x80808080 A4 : 0x00000100 A5 : 0x00000028
A6 : 0x00000003 A7 : 0x00000010 A8 : 0x00060021 A9 : 0x3ffd17b0
A10 : 0x3ffd1a44 A11 : 0x00000000 A12 : 0x00000000 A13 : 0x18000000
A14 : 0x00000003 A15 : 0x00060023 SAR : 0x00000001 EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000028 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x0000000f
Backtrace: 0x4000c469:0x3ffbd270 0x400d5aed:0x3ffbd280 0x400d60da:0x3ffbd2c0 0x400d6909:0x3ffbd2e0 0x400d48b4:0x3ffbd300 0x400d4cbc:0x3ffbd320 0x400d285f:0x3ffbd350 0x400d2969:0x3ffbd370 0x400d3561:0x3ffbd3a0 0x400d290d:0x3ffbd3c0 0x400d23a0:0x3ffbd3e0 0x4010c0ff:0x3ffbd400 0x40088441:0x3ffbd430
#0 0x400d5aed in ppu_renderbg at lib/nofrendo/src/nes/nes_ppu.c:709
#1 0x400d60da in ppu_renderscanline at lib/nofrendo/src/nes/nes_ppu.c:1033
#2 0x400d6909 in ppu_scanline at lib/nofrendo/src/nes/nes_ppu.c:1089
#3 0x400d48b4 in nes_renderframe at lib/nofrendo/src/nes/nes.c:342 (discriminator 1)
#4 0x400d4cbc in nes_emulate at lib/nofrendo/src/nes/nes.c:434
#5 0x400d285f in internal_insert at lib/nofrendo/src/nofrendo.c:178
#6 0x400d2969 in main_loop at lib/nofrendo/src/nofrendo.c:248
#7 0x400d3561 in osd_main at lib/nofrendo/src/esp32/osd.c:40
#8 0x400d290d in nofrendo_main at lib/nofrendo/src/nofrendo.c:218
#9 0x400d23a0 in app_main at src/main.c:215
#10 0x4010c0ff in main_task at C:\Users\paulo\.platformio\packages\framework-espidf@3.50300.0\components\freertos/app_startup.c:208
#11 0x40088441 in vPortTaskWrapper at C:\Users\paulo\.platformio\packages\framework-espidf@3.50300.0\components\freertos\FreeRTOS-Kernel\portable\xtensa/port.c:134
ELF file SHA256: 987c77306
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:7176
load:0x40078000,len:15564
ho 0 tail 12 room 4
load:0x40080400,len:4
load:0x40080404,len:3904
entry 0x40080638
In the file /nes_ppu.c:709 on this line, it is called memset(vidbuf, FULLBG, NES_SCREEN_WIDTH); The constant NES_SCREEN_WIDTH has a value of 256.
The FULLBG constant is defined as follows:
#define FULLBG (ppu.palette[0] | BG_TRANS)
Where ppu.palette is uint8 palette[32] and BG_TRANS is #define BG_TRANS 0x80
if (false == ppu.bg_on)
return;
