I use ESP-WROOM-32 is normal work in arduino.But same code is slow running speed in PIO.
For example,upload FPS.ino in U8g2 library.
In arduino,value > 5
In PIO,value all is 2.1
I used esp32doit-devkit-v1 But it also works slowly.
Downloaded Version 2.0.0 before, but I haven’t updated it.I will try the versions of what you said.
thanks
I solved it!
The problem is solved after installing espressif 4.0.0 .
I want to know it is why?
Maybe i should installed Arduino-esp32 2.0.5 ,and I will know why
