For a school project, I want to use a header file to store config data. I made a config.h file and placed it in the include folder. To prevent it from loading several times I used wrapper #ifndef.
Now I’m still getting a compiling error: multiple definition of `…’. What am I doing wrong? Is the header file not meant to do this? I would like to use this config in several classes.
.h file with macros as well as variable and function declarations
.c or .cpp file with variable and function definitions
The terms are a bit confusing. The short story is:
Variable declarations declare that a variable exists but do not allocated any space for it. It looks like so:
extern uint32_t detectDelay;
Variable definitions allocate space for a variable and initialize it. They also declare it. It looks like so:
uint32_t detectDelay = 10;
Function declarations declare that a functions exists and what parameter it has but do not generate any code:
int add_numbers(int a, int b);
Function definitions generate the code for a function. They also declare it:
int add_numbers(int a, int b) {
return a + b;
The problem in your code is that the header files contains declarations. So there is space allocated for the variable multiple times and these allocations are in conflict.
