ESP32 I2S stops working when building with arduino AND esp-idf framework
I have a simple code reading an i2s microphone on an esp32 written with Arduino. The code runs fine when I build with framework=arduino only.
As soon as I build with famework=arduino,esp-idf the i2s output is only zeros.
I have no issues with my code otherwise. Any ideas?
This works:
[env:featheresp32]
board = featheresp32
-D ESP32
I2S output only zeros:
[env:featheresp32]
framework = arduino, espidf
-D ESP32
platform_packages =
framework-arduinoespressif32 @ GitHub - espressif/arduino-esp32: Arduino core for the ESP32
This is the code I am running:
#include <stdio.h>
#include “driver/i2s.h”
#include <soc/i2s_reg.h>
#define SAMPLE_RATE 8000
#define MIC_SAMPLES_BUF 250
i2s_config_t i2s_config = {
.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX),
.sample_rate = SAMPLE_RATE,
.bits_per_sample = I2S_BITS_PER_SAMPLE_32BIT,
.channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
.communication_format = i2s_comm_format_t(I2S_COMM_FORMAT_I2S),
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
.dma_buf_count = 20,
.dma_buf_len = MIC_SAMPLES_BUF,
.use_apll = false,
.tx_desc_auto_clear = true,
.fixed_mclk = 0
const i2s_pin_config_t pin_config = {
.bck_io_num = 27, // BCKL
.ws_io_num = 13, // LRCL
.data_out_num = -1, // not used (only for speakers)
.data_in_num = 12 // DOUT
i2s_driver_install(I2S_NUM_1, &i2s_config, 0, NULL);
i2s_zero_dma_buffer(I2S_NUM_1);
i2s_set_pin(I2S_NUM_1, &pin_config);
uint8_t i2sData[MIC_SAMPLES_BUF*4];
size_t bytes_read = 0;
void loop()
i2s_read(I2S_NUM_1, &i2sData, sizeof(i2sData), &bytes_read, portMAX_DELAY);
int32_t *samples = (int32_t *)i2sData;
Serial.println(String(samples[0]));
found the error. platformio uses version 4.0 of esp-idf when combined with arduino, and for some reason left and right i2s channels are swapped in this version.
Hm no in the latest version we use 4.1 (see Releases · platformio/platform-espressif32 · GitHub).
Have you made sure to update your platforms (CLI → pio platform update) to have “Espressif32 version 2.1.0”? Is the bug still present in the there-used ESP-IDF 4.1?
I have the same problem! I am using esp-idf framework. When I used framework versions under 2.0, I2s works fine, but when I update framework to version 2.1, it doesn’t. I use i2s to read from adc, I tried to read both, left and right channels but doesn’t work.
Did you found what the problem is?
You mean platform version and not framework? platform-espressfi32 version 2.0 runs on ESP-IDF v4.1. The newest 3.0 runs on ESP-IDF v4.2, even. Maybe the bug is not present there? Otherwise I’d recommend posting to Issues · espressif/esp-idf · GitHub.
In sdk 3.0 the problem disappears
ESP32 I2S works fine with the latest PlatformIO and ESP-IDF v4.2.1.
Depending on which MEMS I2 microphone you are using, the left or right i2s channels may need to be switched.
@michikite
In case M5Atom Echo, If I read M5Atom.h first and read driver/i2s later, I succeed compile.
That mean, Type A is NG, Type B is good.
Type A
#include <driver/i2s.h>
#include <M5Atom.h>
Type B
#include <M5Atom.h>
Maybe, we must update first.
can you provide me working code I am facing quite some issues my code compiled well but I think my microphone imnp441 has an issue will check today with usb logic analyzer to see whether I got the PCM signal or not but I am quite sure I also made mistake in code.
